Ran the Stock Crx at the Track.
I went to the strip tonite for my VERY first time.
stock 88 crx si with muffler.
My times are as follows..
1st run.
.773 reaction
2.973
ET was 17.340
MPH. 83.814
I dropped the clutch too fast and redlined instantly..... this was my best reaction time.
2nd run.
1.184 reaction (I didn't even drop the clutch. I just went. no peeling out.
2.7
16.626 ET
85.272 mph.
Third run.
1.153 reaction. dropped it alittle from 15OO rpms.
2.44
16.292 at 84 mph.
Forth run.
1.65 reaction
2.43
16.224 at 84.98
Is this a good time? Think i could muster 16 flat? with higher rpm launch and feather the clutch better?
1st run.
.773 reaction
2.973
ET was 17.340
MPH. 83.814
2nd run.
2.7
16.626 ET
85.272 mph.
Third run.
2.44
16.292 at 84 mph.
Forth run.
1.65 reaction
2.43
16.224 at 84.98
thats prety decent times for your setup if you ask me, 88 is the lightest, and 105hp stock instead of 108.. its pretty decent...
But if you ask other HT people, then your stock CRX Si should run 14.9 :/
ha ha, i'm using a stock suspension along with some almost bald Bridgestone all season tires. there's about 1/8th of tread left. A fellow 4G civic with 92-95 ex motor/tranny that ran 15.5 on steelies. His was a 2.3 60ft. Said he had around 125 hp. gutted hatch and adjustable struts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">thats prety decent times for your setup if you ask me, 88 is the lightest, and 105hp stock instead of 108.. its pretty decent...
But if you ask other HT people, then your stock CRX Si should run 14.9 :/</TD></TR></TABLE>
YUP I ran a 15.0 with the stock motor with 235kms. Rob
GroundZer0 336
Jul 31, 2003 09:42 PM
SpyLude92
May 25, 2003 07:02 PM
LSBeast
16
Jan 28, 2002 02:47 PM
