where to pin airfuel on ECU? obd1
Old Dec 10, 2003 | 08:57 PM
Nextelbuddy's Avatar
Default where to pin airfuel on ECU? obd1
i have had my air fuel gauge hooked directly to my O2 sensor (white wire) and it was working fine and now it doesnt work anymore. i changed to a new o2 sensor and satill the air fuel gauge doesnt work. so i am going to try tapping the ECU but ther are 2 different o2 sensor wires on teh ecu. one wire is at A6 (orange/black)and it says it is o2 sensor heating element. and the other place is D14 (white/red) and that says just o2 sensor. i dont know which one to tap. any help?
_______
Old Dec 10, 2003 | 09:00 PM
sohcvtec1995's Avatar
Default Re: where to pin airfuel on ECU? obd1 (nextelbuddy)
it might be the A/F meter. unless some othere wire came loose, like a ground or something. since technically you are tapping the same wire, whether it be at the sensor or at the ecu.
Old Dec 10, 2003 | 09:04 PM
Default Re: where to pin airfuel on ECU? obd1 (sohcvtec1995)
well i thought that too but i also have my apexi turbo timer
(has airfuel on it as well) wired with the autometer one and it is not reading the o2sensor as well. i dont know why both of them would not be working. at least one of them should be working.
Old Dec 10, 2003 | 09:05 PM
is there some kind of fuse or something?
Old Dec 10, 2003 | 09:07 PM
nope. i need to start off by eleiminating one or the other by wiring to the correct wire on the ecu. ill start off with the apexi first cuz i know that has to be good then the autometer.
Old Dec 10, 2003 | 09:10 PM
just try that then take the autometer gauge out it see if the apexi works. and then try it with just the autometer gauge. or just find a friend with a civic (we all have friends with one.) and try it on that car.
crxsimike
Apr 10, 2006 04:43 PM
n00bs suck
Jul 23, 2004 07:22 PM
DLB1994
Dec 13, 2003 07:25 PM
