Autometer tach surging above 5k rpms???? Anyone have any ideas why?
Old Dec 10, 2003 | 07:53 PM
LSTurboCivic4dr's Avatar
Default Autometer tach surging above 5k rpms???? Anyone have any ideas why?
Hey I have a 89 Civic LX with a 2000 b18b and it is all running off a 90 integra LS PR4 ECU and wire harness. I was having troubles with the factory tach surging above 5k rpms, like it would just bounce up real fast! So i figered **** it, I would just install a nice sport comp 5 inch unit and that would take care of it, well i hooked it up to my MSD box, and I am still having the same problem, it sux because when it surges into the higher RPM's, it causes the shift light to come on and i am only at like 5500! If anyone has any ideas let me know, Thanks, Frank.
Old Dec 10, 2003 | 09:14 PM
slooogsr's Avatar
pop ur distributor cap off, check the wires on the ignitor....... should be like 4wires on it. pop em off and clean them up good. you could possibly have a loose connection as well. make sure everything is kool with ur tach wiring as well. i had the same problem and cleanin up all the connections solved it.
Old Dec 10, 2003 | 09:56 PM
Jester88Si's Avatar
Default Re: Autometer tach surging above 5k rpms???? Anyone have any ideas why? (LSTurboCivic4dr)
I had a similar problem on my old integra it was due to one of my ignitor wire's rubber protector thing being torn....open up the dizzy and check it out
Old Dec 11, 2003 | 05:07 AM
Downs's Avatar
Default Re: Autometer tach surging above 5k rpms???? Anyone have any ideas why? (Jester88Si)
I had the same problem with my autometer tach. The problem was that my power wire was too small, so I just rewired it with 10 gauge wire.
Old Dec 11, 2003 | 06:56 AM
slooogsr's Avatar
Default Re: Autometer tach surging above 5k rpms???? Anyone have any ideas why? (Downs22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downs22 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my autometer tach. The problem was that my power wire was too small, so I just rewired it with 10 gauge wire.</TD></TR></TABLE>
shouldnt be drawing that much current......... my guess is you had a loose connection that u fixed while rewiring it............ car radio's dont even have 10gauge wire for the + power........... anyways u fixed it.
Old Dec 11, 2003 | 08:59 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Autometer tach surging above 5k rpms???? Anyone have any ideas why? (sloorex)
High rpm bouncing tach usually means a crappy ignitor is just about to die.
If your still running the stock one, (Im not familar with the MSD setup)
Blaze
soad1234
Aug 19, 2007 01:45 PM
MeatballHB
Dec 14, 2005 11:55 AM
b18c5hatchie
Jul 2, 2004 06:59 PM
4door-r
Apr 23, 2004 04:01 PM
crashtest Sonny
13
Sep 4, 2002 04:20 PM
