lower RPMs with larger exhaust??
Old Dec 10, 2003 | 05:35 PM
elmerfudd's Avatar
Default lower RPMs with larger exhaust??
I have a 1990 with short ram intake, 4-2-1 header and now I have 2.25" exhaust from the catback with flowmaster muffler. I don't think this is my imagination, but after adding the 2.25 exhaust my RPMs dropped 200. RPMs went from like 4000 to 3800 at 80 miles an hour. Does this make sense??? I have the stock motor, plan on doing the minime here soon. Did anyone notice thier rpms lower after going to a larger dia. exhaust?? It is louder by all means, but my car did pass emissions
thanks for the input.
laters,
Elmerfudd
Old Dec 10, 2003 | 05:43 PM
sporkcrx's Avatar
Default Re: lower RPMs with larger exhaust?? (elmerfudd)
it's your imagination
Old Dec 10, 2003 | 05:57 PM
yellowcrx1991's Avatar
Default Re: lower RPMs with larger exhaust?? (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">it's your imagination</TD></TR></TABLE>
I'll agree.
Old Dec 10, 2003 | 11:32 PM
StorminMatt's Avatar
Only gearing changes can change RPMs.
Old Dec 11, 2003 | 06:11 AM
dilbert's Avatar
Default Re: lower RPMs with larger exhaust?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Only gearing changes can change RPMs.</TD></TR></TABLE>
there is no possible way that having a more open exhaust can make your gearing change! The only think I noticed when I have my silencer out vs silencer in on my exhaust(4-1, 2.25" full, test pipe, straight through muffler) is that I have a drop in low rpm power with it out.
Old Dec 11, 2003 | 08:03 AM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmerfudd &raquo;</TD></TR><TR><TD CLASS="quote">RPMs went from like 4000 to 3800 at 80 miles an hour. </TD></TR></TABLE>
You mean it USED to be 4k RPM when going 80mph and now it's 3.8k RPM when going 80mph?
Well you can't predict land speed (mph) by RPM only. There are too many variables in the equation (i.e. road conditions, weather, engine power output @ xRPMs). Maybe your motor simply makes more power earlier in the RPM band since you put on the exhaust? I don't know. Or maybe you just had more traction that day. Or less wind-resistance. Or maybe you lost some weight, or maybe your car lost some weight. A hypothetical example: Take your car and drive it on the road and note the speed at 2nd gear redline. Then take the same car on the same tires and drive it on some ice- A glacier or something. Note the speed at 2nd gear redline...and it'll be different; obviously. RPM alone does not determine mph.
But it could be your imagination too.
Old Dec 11, 2003 | 03:28 PM
Default Re: lower RPMs with larger exhaust?? (R_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R_EG &raquo;</TD></TR><TR><TD CLASS="quote">
But it could be your imagination too.</TD></TR></TABLE>
Besides gearing, the only other thing that changes the RPM vs speed relationship is overall wheel diameter. All the other stuff (power curve, torque curve, wind resistance, traction, etc.) doesn't make a difference. It can affect how fast the car will accelerate or travel. But not the number of RPMs required to attain a given speed.
98exturd
Jun 4, 2008 10:14 AM
nsl
Honda Civic (2006 - 2015)
Jan 22, 2007 12:48 PM
june_si
Dec 5, 2006 08:00 PM
eluder33
Jun 5, 2006 12:48 PM
Hites
Sep 8, 2003 01:17 PM
