HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!!
Old Sep 19, 2001 | 03:10 PM
RHGSR01's Avatar
New User
Default HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!!
I just installed my Fiber Images Carbon Fiber hood and let me tell you about the fitment. On each side of the carbon fiber hood, there is a 3mm gap between the hood and the fender. Also, the front of the hood sticks up about 2mm. Also, on one side it sits low to the car like perfect; however, on the other side, it lifts up. Can u tell me any tips to make it lower. How do u adjust the hood latch. Also, how do u also adjust the stock rubber stoppers??
Old Sep 19, 2001 | 03:17 PM
DelsolVtec18's Avatar
New User
Default Re: HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!! (RHGSR01)
You'll need a 10mm hand wrench...their is three 10mm screws that you just loosen and then you can adjust the latch...the rubber stoppers can be adjusted my just twisting them
Old Sep 19, 2001 | 03:30 PM
RHGSR01's Avatar
New User
Default Re: HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!! (DelsolVtec18)
Do you mean that I can lower the hood latch??? Also, when I looked I saw two screws on the latch, one on each side, there weren't any other holes that I can make the hood latch sit lower
Old Sep 19, 2001 | 03:51 PM
Pat's Avatar
Pat
there are 3 screws, 2 on the driver side I believe. Once you loosen them, the latch can move around in all 4 directions.
New User
if you loosen the three screws u can move the latch...just loosen the screws and push down the latch it should move. yeah there should be 2 on driver and 1 on passenger side
[Modified by DelsolVtec18, 12:52 AM 9/20/2001]
Old Sep 19, 2001 | 08:22 PM
redGSRguy's Avatar
I loosened the 3 screws and pushed it all the way down but now the hood wont click down a second time, am I doing something wrong or is there something wrong w/my hood or bumper?
Old Sep 19, 2001 | 08:45 PM
Pat's Avatar
Pat
Default Re: HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!! (redGSRguy)
you pushed it too far down. I could only make minute adjustments on my latch, otherwise the hood wouldn't shut.
Old Sep 20, 2001 | 06:06 AM
newsense's Avatar
New User
Default Re: HELP WANTED!! Just INSTALLED C/F HOOD and STICKS UP!! (Pat)
you have to repeatedly play with it..... took me like 4 trys to get it right
integraty95
Apr 21, 2009 01:18 AM
Feuerraeder
Nov 25, 2003 03:45 PM
CivSOHC
Apr 28, 2003 12:28 PM
RHGSR01
Sep 19, 2001 09:09 PM
RHGSR01
Sep 17, 2001 04:50 PM
