Need Help Choosing Tires
Old Dec 10, 2003 | 10:45 AM
DIYaccord's Avatar
Default -Need Help Choosing Tires
ok, first things first.
for chirstmas my dad is gonna help pay toward a new set of tires for me. (1/2) but they gotta be from costco tire (basicly bridgestone potenzas and michilin only) i've got absolutly no complaints about that.
i need a tire that is all season (wa weather), and is good for autoXing.
my current bridgestone re920's lasted pretty long (bout two years) and that was with about 4 autoXing and constant aggressive driving.
right now they're almost bald and i need new ones...
the only thing i want to look at most was that after this last AutoX i went to the sidewall would i guess you would say "roll over" and the "edge" looks like it went through a cheese grater.
i'm looking into these tires:
RE950
RE910
S-03
anybody care to give an oppinion or experience?
also, would it be wise to invest in a 2nd set of wheels just for AutoXing (mostly for tire life)? or should i be ok? (it's hard to be a senior in high school...no $)
Modified by DIYaccord at 1:06 PM 12/10/2003
Old Dec 10, 2003 | 11:01 AM
getfast's Avatar
Default Re: Need Help Choosing Tires (DIYaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my current bridgestone re920's lasted pretty long (bout two years) and that was with about 4 autoXing and constant aggressive driving.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the only thing i want to look at most was that after this last AutoX i went to the sidewall would i guess you would say "roll over" and the "edge" looks like it went through a cheese grater.</TD></TR></TABLE>
That sounds like a tire pressure and/or alignment problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also, would it be wise to invest in a 2nd set of wheels just for AutoXing (mostly for tire life)? or should i be ok? (it's hard to be a senior in high school...no $)</TD></TR></TABLE>
IMHO don't worry about that stuff, just drive the car
Old Dec 10, 2003 | 11:04 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking into these tires:
RE950
RE910
S-03
Costco doesnt carry the RE950 or S-03.
Old Dec 10, 2003 | 11:11 AM
Xian's Avatar
Default Re: Need Help Choosing Tires (getfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getfast &raquo;</TD></TR><TR><TD CLASS="quote">That sounds like a tire pressure and/or alignment problem.
Either tire pressure or overdriving the car and burning up the front, outside edge.
Yep, just get a decent set of all season tires and drive it!
Old Dec 10, 2003 | 12:05 PM
DIYaccord's Avatar
Default Re: Need Help Choosing Tires (Xian)
yeah, my costco does carry all those that i listed
by just drive, do you mean AutoX with whatever i have or...don't autoX...i'm confused
i was running at 40psi in my 185/60/14 stock tires...and i was driving kinda hard...what do you mean by overdriving?
Old Dec 10, 2003 | 12:08 PM
getfast's Avatar
Just autoX with what you've got. Focus on the driver, not the car
Old Dec 10, 2003 | 12:10 PM
getfast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">i was running at 40psi in my 185/60/14 stock tires...and i was driving kinda hard...what do you mean by overdriving?</TD></TR></TABLE>
Forcing an understeering car with improper alignment and/or not enough air pressure into tight autocross corners well beyond the grip at the front end = overdriving = front tire outside edge/sidewall destruction.
Old Dec 10, 2003 | 12:52 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: -Need Help Choosing Tires (DIYaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">i need a tire that is all season (wa weather), and is good for autoXing.</TD></TR></TABLE>
That's a problem.
Tires that are all season are designed for snow. They have deep gaps between the tread blocks, and are designed to have a wide range of operating temperatures. They are almost always poor for autocross.
Tires that are designed to do well in high performance driving are usually awful in snow.
If you really have to be able to drive in snow, then get a set of winter tires to use during the winter, and use a high performance summer tire the rest of the year. Remember that many of the high performance summer tires, like the Bridgestone S-03, Yokohama ES100, etc, are excellent in rain too - just not on snow. And they can do okay at autocross, too.
If you are autocrossing competitively and every hundredth of a second matters, then you may want to get a set of R compound tires designed for that purpose, such as Hoosier A3S03.
Old Dec 10, 2003 | 08:29 PM
DIYaccord's Avatar
so, get a set for just autoXing...and then a set for everything else?
i don't make alot of money (senior in high school)
pumafeet10
Oct 17, 2007 07:37 PM
speedyls2000
Aug 6, 2006 08:59 PM
Ross2852
Jul 5, 2005 10:35 AM
crewjones
Nov 13, 2004 08:13 PM
DIYaccord
Dec 12, 2003 11:05 AM
