check out my alignment specs.... does it look alright?
Old Sep 19, 2001 | 01:37 PM
keys's Avatar
Default check out my alignment specs.... does it look alright?
does this look alright?
Old Sep 19, 2001 | 02:03 PM
red97gsr's Avatar
Default Re: check out my alignment specs.... does it look alright? (keys)
Is the car stock? Those settings are what I would expect if the car is stock.
Old Sep 19, 2001 | 02:59 PM
crookedletterd's Avatar
New User
Default Re: check out my alignment specs.... does it look alright? (red97gsr)
how do you know what to set your alignment to??? i mean do you bring the car in and have the guy do it or do you guys tell them certian toe, camber etc??? whats the advantages/dis.
Old Sep 19, 2001 | 03:02 PM
keys's Avatar
Default Re: check out my alignment specs.... does it look alright? (integls98)
actually my car is lowered on ground control's and illuminas and i'm also using an ingall's camber kit.....
Old Sep 20, 2001 | 02:34 PM
red97gsr's Avatar
Then, I would dial in more negative camber. More negative camber will help the tire stick better on hard turns. Try to have more negative camber in front than back and it'll help you reduce understeer just a little too. I'm using -1.3f/-.075r, but some people use more camber than that. Just keep your toe aligned and you'll be OK with tire wear.
TonyRomo
Jul 20, 2009 01:24 PM
balili89
Feb 20, 2008 05:57 AM
TegGsr4dr
Jul 10, 2007 09:35 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
ALF
Aug 16, 2001 05:47 PM
