Spark plugs, What do you have in your car right now?
Old Dec 10, 2003 | 08:50 AM
Bbasso's Avatar
Default Spark plugs, What do you have in your car right now?
And what are your mods for anything other then the stock plugs?
If you use something specific please say why.
Just wanted to know...
Old Dec 10, 2003 | 08:54 AM
Eric R's Avatar
Default Re: Spark plugs, What do you have in your car right now? (Bbasso)
Stock platinum NGK's all the way!
Old Dec 10, 2003 | 09:12 AM
Tweakmeister's Avatar
Rocket Motorsports (artist formerly known as EF-1) modified spark plugs.
Definate improvement.
Old Dec 10, 2003 | 09:24 AM
Opie's Avatar
Default Re: Spark plugs, What do you have in your car right now? (Tweakmeister)
I use the NGK iridium temp 7's. Recomended by inline4 definate improvment on the butt dyno car idles much smoother.
Old Dec 10, 2003 | 09:34 AM
SoCal ITR's Avatar
Default Re: Spark plugs, What do you have in your car right now? (opie112)
Interesting.... it's getting about that time where I have to replace mine...
Old Dec 10, 2003 | 09:39 AM
AJ PwR's Avatar
NGK IX Temp 7 Iridiums.
Old Dec 10, 2003 | 09:52 AM
woodog's Avatar
bosch platinum 2's.
set of 4 costs same as ONE ngk plat.
Old Dec 10, 2003 | 09:54 AM
RTW DC2R's Avatar
OEM NGK Legend plugs, temp range 6 I believe.
Old Dec 10, 2003 | 10:02 AM
Rdriver's Avatar
Default Re: (RTW DC2)
NGK-R PFR7G-11. Stock JDM R plug/S2000 plug. I paid $30 for 2 sets brand new.
Old Dec 10, 2003 | 10:12 AM
RockstarJR's Avatar
NGK Platnum
Old Dec 10, 2003 | 10:58 AM
Austin's Avatar
NGK Copper 2756 V-Groove
Old Dec 10, 2003 | 11:31 AM
Willard's Avatar
NGK BKR7EVX-11
-cheaper than OE
Old Dec 10, 2003 | 11:46 AM
Smitdog's Avatar
Default Re: Spark plugs, What do you have in your car right now? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">NGK BKR7EVX-11
-cheaper than OE</TD></TR></TABLE>
What I am running!
Old Dec 10, 2003 | 11:48 AM
mstewar's Avatar
i've got a set of OEM on the way..
Old Dec 10, 2003 | 12:54 PM
ITR-00-1457's Avatar
Default Re: (mstewar)
Denso Iridium ISO7
Old Dec 10, 2003 | 01:25 PM
Euro98ITR's Avatar
Default Re: (ITR-00-1457)
I never removed my plugs because my R still has 12K miles. Do all Rs JDM/EURO/USDM have the same stock plugs?
Old Dec 10, 2003 | 01:52 PM
Kendall's Avatar
Denso Iridium and love them.
Old Dec 10, 2003 | 02:05 PM
hYpE-R-29's Avatar
Default Re: (dc231)
I am going to be installing...Denso Double Platinums Pk20-11 in about 30 minutes...same as the NGK OEM double Platinum's...and I got them for $6.99 each..wohooo
Old Dec 10, 2003 | 02:07 PM
JjuuN R's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Denso Iridium and love them.</TD></TR></TABLE>
Old Dec 10, 2003 | 05:27 PM
hYpE-R-29's Avatar
Default Re: (hYpE-R-29)
Just installed the Denso Double Plat's..throttle response feel alot better, good quality shiettt
Old Dec 10, 2003 | 05:48 PM
r573's Avatar
still pushing oem,s
Old Dec 10, 2003 | 08:02 PM
Rhetoric's Avatar
Default Re: (r573)
Autolite 3923 gapped at .038
Old Dec 10, 2003 | 08:53 PM
TeamNextGenChris's Avatar
regular old NGK Rs...i've tried the iridium/platinum crap and couldn't tell any difference,let alone justify the cost.only advantage i can see is the longer lifespan.but,when you consider you can buy about two sets of regular NGKs for the price of ONE of the exotic plugs,you can afford to change them at shorter intervals and still save money.
i run stock heat range NGKs in my beater,and 1 step colder in the turbo motor.
i've seen too many people on other boards rave about the latest $10 a piece plugs and how they felt a huge HP gain.they forgot to mention they're comparing them to the stock plugs that had 80K miles on them.on the dyno,switching from a brand new NGK copper plug to ANY other plug,with evrything else being equal,i'm sure would produce negligible gains.
chris
Old Dec 10, 2003 | 09:00 PM
98itR484's Avatar
Default Re: Spark plugs, What do you have in your car right now? (TeamNextGenChris)
bosch 4227 plugs.....$1.99 each change them every other oil change.
Most say it doesnt work w/ high compression, but im higher than stock, and got high lift cams, and it does great. Even tested on the dyno to make power at IB.
Old Dec 10, 2003 | 09:24 PM
Tommy_Gunns's Avatar
