What 88-91 CRX Door will fit the 88 CRX Si?
Old Dec 10, 2003 | 08:49 AM
B2FiNiTY's Avatar
Default What 88-91 CRX Door will fit the 88 CRX Si?
Are they all the same? I am talking about replacing the metal door sking but keeping the 88 crx si interior door panel.
Old Dec 10, 2003 | 09:19 AM
EL Vap133's Avatar
Default Re: What 88-91 CRX Door will fit the 88 CRX Si? (B2FiNiTY)
I believe you can ony use 88 doors, and an 89 HF door....
Old Dec 10, 2003 | 04:09 PM
B2FiNiTY's Avatar
Default Re: What 88-91 CRX Door will fit the 88 CRX Si? (EL Vap133)
Why is that though?
Old Dec 10, 2003 | 04:35 PM
EL Vap133's Avatar
Because of the door mounted seatbelts...
Old Dec 10, 2003 | 04:47 PM
XJamesX's Avatar
I think all the door skins are the same but the actual doors are diff from the 88s and 89-91's. the 88 crx's had pillar mounted belts and so did the 89 HF's everythign else had door mounted belts. Teh actual doors are diff but the skins are the same.
-James-
Old Dec 10, 2003 | 05:21 PM
another_crx's Avatar
Default Re: What 88-91 CRX Door will fit the 88 CRX Si? (B18C5crx)
Was gonna make my own thread but I guess I dont have to. Could anyone tell me what doors fit a 89 Crx Si?
Its does not have door mounted seat belts and the car I want to buy has rusty doors so I wanna swap em out
Old Dec 10, 2003 | 05:45 PM
B2FiNiTY's Avatar
Yeah, I meant everything but the door panel.
For example:
89 CRX door with the 88 inner door panel.
Old Dec 10, 2003 | 06:46 PM
juanb's Avatar
well i think they all fit but, the 90-91 door molding is thicker than the 88-89 door molding. and u might also have the trouble with the seat belt too!!
Old Dec 10, 2003 | 07:07 PM
ITSTOCK's Avatar
Default Re: (juanb)
all u have to do with a 90-91 door is just unbolt the seatbelt setup, and use the 88 seatbelt setup. and also put your 88 molding on the door since the 90-91 is thinner.
i no this from hands on experience, not from what my brothers gf's cousin read online
Old Dec 10, 2003 | 11:33 PM
StorminMatt's Avatar
Default Re: (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">all u have to do with a 90-91 door is just unbolt the seatbelt setup, and use the 88 seatbelt setup. and also put your 88 molding on the door since the 90-91 is thinner.
i no this from hands on experience, not from what my brothers gf's cousin read online </TD></TR></TABLE>
But why would you want to use 1990-1991 doors? People get 1988 cars (and 1989 HF models) simply to avoid the increased weight of 1989-1991 doors.
Old Dec 10, 2003 | 11:39 PM
^jefs0ng's Avatar
Banned
damn hybrids of the hybrids.. for REALS
Old Dec 11, 2003 | 04:25 AM
sircrxracer's Avatar
Default Re: (.jefs0ng)
Get any year of doors from a Canadian model the all have pillar mount seat belts. Rob
Old Dec 11, 2003 | 06:04 AM
dilbert's Avatar
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
But why would you want to use 1990-1991 doors? People get 1988 cars (and 1989 HF models) simply to avoid the increased weight of 1989-1991 doors.</TD></TR></TABLE>
I am canadian so I don't know this for sure but I believe the 88-89 us doors didn't have side impact bars, but the 90-91's did. Where as the canadian doors always had the pillar mounted seat belts(as was already stated) and always had side impact bars(I have a 89 door on my 90 crx).
Old Dec 11, 2003 | 06:27 AM
Timmah!!'s Avatar
Default Re: (dilbert)
I need a door too, and have come to the understanding that (in US models) the 88(all) and 89(HF) is the one you HAVE to use. I don't know what the deal is with using just the shell from and 89=-91, but I know the 88 will work. Now I don't believe the 88-89 had the impact bars in the door, thus making them lighter.
Either way I still need a drivers side door
Old Dec 11, 2003 | 05:40 PM
Default Re: (azroth)
So what doors fit my 89 Crx SI?? (BTW I am from canada) will all kinds from every year work in canada?
Old Dec 11, 2003 | 07:51 PM
filthyCREX's Avatar
Default Re: (InsaneDB)
i actually think they're different..
they seem the same, but seriously, i rewired a 90 with 89 wires.. and honestly, it's much different! so it wouldn't surprise me if they were different.
Old Dec 11, 2003 | 10:54 PM
Vinceg99's Avatar
Default Re: (filthyCREX)
I dont understand how they could be the same?? I mean the 88's and 89 HF's have different windows than the 89 DX's and Si's and the 90/91's so how could they be the same?? Now they may bolt on but I think if anything it would look goofy since there are more differences than just the seatbelts on the doors...Like the metal bar or whatever you would call it under the door that goes into the loop on the door sill or the size of the door sashes. I think you should stick with the door that was meant for your car so all 88's and 89 HF's with eachother and 89 DX's,Si's and 90/91's with eachother. Now what about the star head bolts on the sides of the doors?? Do 88's and 89 HF's have those as well?? They are 2 like bolts with wider heads that use a star key to put them on I think they have something to do with supporting the door so it doesnt sag I would assume?? But do all years have those as well?
Old Dec 12, 2003 | 08:20 PM
Default Re: (Vinceg99)
So for my car a 89 Crx Si
Doors from a 89 dx/si will fit as well as 90-91 all models?
Im in canada and going to the junkyard tomorrow and this answer will definetely help me
Old Dec 12, 2003 | 11:00 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InsaneDB &raquo;</TD></TR><TR><TD CLASS="quote">So for my car a 89 Crx Si
Im in canada and going to the junkyard tomorrow and this answer will definetely help me</TD></TR></TABLE>
Well if your in Canada you shouldnt have to worry about the year since they are all the same I beleive (none have seatbelts in the doors right)?? Although I think the 88/89's dont have the extra door beam inside them like the 90/91's do?? But again I could be wrong??
Old Dec 13, 2003 | 08:07 AM
Even with that centre beam the doors are still interchangeable right?
Old Dec 13, 2003 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">
Well if your in Canada you shouldnt have to worry about the year since they are all the same I beleive (none have seatbelts in the doors right)?? Although I think the 88/89's dont have the extra door beam inside them like the 90/91's do?? But again I could be wrong?? </TD></TR></TABLE>
Your right we do not have door mounted seat belts as my post says above and the center beam is on all years excpet 88. Rob
Ryude
Jul 10, 2018 05:55 AM
joeyblow
Oct 2, 2005 02:41 PM
dtown_racer
Feb 21, 2005 04:35 AM
turbo sol
Sep 15, 2003 02:13 AM
