accord is it transmision problem
Old Dec 10, 2003 | 05:31 AM
alb_accord's Avatar
Default accord is it transmision problem
i have a 90 accord ex and when i was driving in the snow i pushed the gas pedal to go faster and the car didn't go. the gas pedal got hard and there was no change in the car likei wasn't doing anything. i took my foot off the gass pedal and pushed it again then the car accelerated. it did the same thing in dry asfalt. i am driving about 30 mph and i try to accelerate but the gass pedal becames hard to push i push it to the end and nothing happens i take my foot off then push it again then the car accelerates. is it trasmision problem or something else i have no idea. someone please help
Old Dec 10, 2003 | 05:59 AM
JimBlake's Avatar
Default Re: accord is it transmision problem (alb_accord)
That sounds really strange. Start at the pedal itself & check it's hinges. Then go to the throttle cable, then the throttle bode... It sounds to me like there's something physically blocking it from moving.
Old Dec 10, 2003 | 09:53 AM
alb_accord's Avatar
it happens only three times a day. and i took of the air fileter and everything and spry there to see if there is any changes but that didn't do any good. i check it and i don't see anything in it
Old Dec 10, 2003 | 11:03 AM
Nick M's Avatar
Default Re: (alb_accord)
is it an automatic? manual?
Old Dec 10, 2003 | 02:13 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">it happens only three times a day. and i took of the air fileter and everything and spry there to see if there is any changes but that didn't do any good. i check it and i don't see anything in it
looks like you have a tranny that only wants to work when it wants to....and what would the airfilter have to do with your tranny....just curious.
Old Dec 10, 2003 | 04:55 PM
fluxion's Avatar
amin n'rangwa edanea
same thing happened to me on the freeway around 70mph a few times. i reset the ecu and it hasnt happened since, i'm not sure what the cause of it was though.
Old Dec 11, 2003 | 03:48 AM
JimBlake's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">...and what would the airfilter have to do with your tranny....just curious.</TD></TR></TABLE>His profile says he's in Albania. For all I know, a '90 EX came with a carburator in Albania. And his original post sounds to me like a stuck or frozen throttle or throttle cable.
So, alb_accord... Tell us about your car. Carburator? Fuel injection? I bet the USA Accord EX isn't the same as yours. You mention driving in the snow. Does this only happen when it's cold enough to get ice in the throttle linkage?
Old Dec 15, 2003 | 03:31 PM
alb_accord's Avatar
i am albanian but i live in philly usa. so its a accord it usa. the thing is when the gas pedal gets hard and i push it to the end i hear some cranking noises coming from the automatic transmision. its like cranking noises it cranks like three or four times then the car is good again. one other way to make my car accelerate is i have to keep the pedal pushed steady so it can pass that problem. i changed the oil and it still does that **** to me. so if u have any idea tellme about it please
Old Dec 15, 2003 | 08:51 PM
hondafied's Avatar
on the tranny, if its auto, there a detent linkage that the throttle is connected to directly. if that detent is sticking, it will cause the pedal to bind. its on the front of the tranny to the left of the cooler lines. it has a cable going directly to it. you should be able to pull it up with your hand. if it binds or grinds at all you have a problem in the tranny.
Old Dec 16, 2003 | 08:44 AM
alb_accord's Avatar
i know what u are talking about. it's in the left side of the trany. now i move it up and down with my hand and it seems to be ok. do i have to disconect the cable from in and pull the arm out. is that what u are telling me to do or what. sorry i don't know alot about it so if u want me to pull it out what do i have to look for to find the problem.
accord_cd5
Sep 1, 2013 08:12 AM
legacy1644
Dec 4, 2010 09:22 AM
NguyenDC2
Feb 3, 2007 09:59 PM
indelible
Dec 10, 2004 11:13 AM
flhtvtwin
Mar 23, 2004 02:48 AM
