Who's using these spark plugs??
Old Dec 9, 2003 | 10:04 PM
hYpE-R-29's Avatar
Default Who's using these spark plugs??
I know the stcok NGK double platinums are the best...but who is using the Denso double platinums, part number #3142m $6.99 each....or the Champion double platinums part#7071 $4.49 each...
Old Dec 10, 2003 | 06:51 AM
Its_real&its_spectacular's Avatar
New User
Default Re: Who's using these spark plugs?? (hYpE-R-29)
Don't put Champions in a Honda. For that matter, try to avoid putting Champions in anything...
NGK = great plugs...
Old Dec 10, 2003 | 08:39 AM
iperez's Avatar
I've had a couple of plugs on the car ..
OEM: very good performance
Bosch +2: Nice ***-dyno feeling. Probably a little better performance over the stock plugs but only lasted a few months.
Denso Iridium: Just ordered these. I'll post as soon as I get them.
Old Dec 10, 2003 | 08:44 AM
B2FiNiTY's Avatar
Denso is fine as long as you get the right heat and gap.
Old Dec 10, 2003 | 09:27 AM
hYpE-R-29's Avatar
Default Re: Who's using these spark plugs?? (B2FiNiTY)
Im really looking into the Denso Double Platinums...the Acura dealer sells them for $19.00 each and the same ones at Autozone are only $6.99 each....and they come pre-gapped and are double plat's....the acura dealer sells them as a replacement for the NGK OEM double plat's.....Should I go ahead and grab the Denso's if the Acura dealer sells them as replacement's....?? Also is the heat range the same as the NGK"s??
Old Dec 10, 2003 | 09:35 AM
SoCal ITR's Avatar
Good question... I need to replace mine soon, and I wanna put the best ones in... is there any consensus on which ones are the best?
Old Dec 10, 2003 | 09:38 AM
DsITR's Avatar
Default Re: Who's using these spark plugs?? (SoCal ITR)
I run NGK coppers in all my hondas..have yet to change the plugs in the R yet though.
Bosch platinums run like ish in any thing but my old S10 (4.3L V6), stepdad's C4 vette(5.7L) and Mom's Durango (5.9L)....basically big displacement domestics.
dman81
Feb 2, 2014 11:10 AM
sExy_TinKY
Oct 27, 2004 08:31 PM
SpyderZEX
Aug 28, 2003 04:58 AM
dp
May 25, 2002 11:47 AM
