k24 Ivtec block Piston swap with S2000 or h22a series all have 87mm stock bore sizes....
Old Dec 9, 2003 | 06:28 PM
HotWheelz's Avatar
Default k24 Ivtec block Piston swap with S2000 or h22a series all have 87mm stock bore sizes....
the k24 block has a 87mm bore...
well so does s2000, and also h22a.
so since the head designs are almost all the same, wouldn't that mean that we could introduce a type-s piston (11.0cr) piston instead of the 10.5cr that the TSX gets???
i'm curious to hear imput because these pistons can easily aquired..
something to think about..
what happens if you put an FRM designed piston in a "STEEL" sleeve ??? nothing or would something happen...
because getting a CRV block and dropping some Prelude type-S pistons would be a cheap 11.0cr block upgrade... don't ya think ?
please keep the thread clean
Old Dec 9, 2003 | 06:55 PM
GreenR's Avatar
Default Re: k24 Ivtec block Piston swap with S2000 or h22a series all have 87mm stock bore sizes.... (HotWhe
Do a search I think this question has come up be4. Wasn't too long ago I think.
Old Dec 9, 2003 | 06:58 PM
HotWheelz's Avatar
under what ?
Old Dec 10, 2003 | 03:30 PM
RStoR's Avatar
You need to compare the following info to determine if this is even possible
Pin size
Compression height
Dome displacement
Old Dec 10, 2003 | 04:24 PM
Benny Hinn's Avatar
Don't forget pin size also.
If you were to build a bottom end, why use a stock piston? It seems like spending the extra money for some aftermarket pistons that are stronger and lighter would be worth the extra 150-200 dollars.
Old Dec 11, 2003 | 09:38 AM
lube's Avatar
The type s has an 86mm bore, not 87mm.
Old Dec 11, 2003 | 09:49 AM
Benny Hinn's Avatar
Prelude type s pistons are 87mm
Old Dec 11, 2003 | 01:12 PM
HotWheelz's Avatar
k24 block has a bore of 87mm, when i was talking about the type-S i ment the prelude type-s pistons which are 87mm in bore.. H22a block = 87mm bore same as k24 and also same as s2000.
Fei
Aug 16, 2009 10:09 AM
92_civic_lx
Dec 20, 2008 05:59 AM
Maddox
Feb 13, 2005 08:30 AM
LudeHatchH22a
Mar 6, 2004 01:19 PM
