is it worth to get an aftermarket ECU for a 96 ACcord?
Old Sep 19, 2001 | 10:29 AM
rdtx's Avatar
New User
Default is it worth to get an aftermarket ECU for a 96 ACcord?
MT transmission...
i'm starting to get interested in tuning up my car... got any recommendations?
Old Sep 19, 2001 | 12:53 PM
m0t0rhead's Avatar
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (rdtx)
Don't bother sinking money into that engine. Swap out for an H22.
Old Sep 19, 2001 | 01:45 PM
4doorH22's Avatar
If you do stick with the F22, an ECU should be a later upgrade. You want to improve aspiration first (intake, header, and exhaust) and then get a new ECU to take advantage of the improved breathing.
Old Sep 19, 2001 | 05:31 PM
tensai's Avatar
New User
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (Escobar)
i agree with Escobar...i think that you should get an h22 swap. IMO, these engines arent worth it to try and make them faster.
Old Sep 19, 2001 | 05:36 PM
SOHCArchangel's Avatar
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (whiteconfusion)
96, OB2, yeap, the f22 has plenty of power potentioal, all you need to know is where to start, and what needs to be done
Old Sep 19, 2001 | 06:46 PM
tensai's Avatar
New User
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (SOHCkordVTEC)
*ahem* F.I. *ahem*
[Modified by whiteconfusion, 3:47 AM 9/20/2001]
Old Sep 19, 2001 | 09:54 PM
rdtx's Avatar
New User
thx for the replies... do you know how much these engines swaps may cost?
Old Sep 20, 2001 | 05:39 AM
4doorH22's Avatar
Figure $2.5 - 4K for the engine/tranny, $1 - 2K for the labor (a lot of people save by doing it themselves), and you should budget at least another $1K for miscellaneous parts and problems.
Old Sep 20, 2001 | 10:50 AM
ArchAngel Sabastian's Avatar
New User
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (4doorH22)
who makes the aftermarket ecu for a 96 kord?
please dont give me all that the motor sucks crap.
Old Sep 20, 2001 | 10:58 AM
4doorH22's Avatar
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (Sabastian)
Well those "drop in" chips are bogus.
Try http://www.hondata.com
Old Sep 23, 2001 | 07:53 AM
rdtx's Avatar
New User
Default Re: is it worth to get an aftermarket ECU for a 96 ACcord? (anyone)
right now i have a H22b under the hood..
but got a stupid question.. what other type of engines will fit under this hood?
Old Sep 23, 2001 | 12:24 PM
4doorH22's Avatar
Any F or H series motor should bolt in with little or no fabrication.
Old Sep 23, 2001 | 07:49 PM
John's Avatar
New User
If you don't want to throw up the cash for an H22 (although it's definitely worth it!), get an Apex V-AFC... that way play with your VTEC threshold and manipulate your air fuel mixture... it's not the same as having an "upgraded ECU," but it'll be able to tailor your A/F ratio to your modifications...
Old Sep 23, 2001 | 07:57 PM
4doorH22's Avatar
[QUOTE]right now i have a H22b under the hood..QUOTE]
What in the world is a H22B anyways?
Old Sep 23, 2001 | 08:14 PM
John's Avatar
New User
i've never heard of an H22B either... anyone know the code for a H22A Spec S motlor (the Type S motor)?
Old Sep 24, 2001 | 04:09 AM
rdtx's Avatar
New User
I dunno.. i could be looking at the wrong numbers
where do i usually find the engine code?
Old Sep 24, 2001 | 07:00 AM
4doorH22's Avatar
Just to the left of the exhaust manifold/header when you're facing the block from the front:
hmmmm my host is having problems...
Old Sep 24, 2001 | 10:31 AM
rdtx's Avatar
New User
ok.. i checked it out..
the engine that i have currently is a F22B1
accordmatt
Dec 17, 2012 11:14 PM
dvp95
Jul 9, 2011 05:29 PM
JDM_TR!CC
Apr 10, 2009 03:14 PM
racerboyb18c1
Dec 29, 2003 02:52 PM
