need some help!
Old Dec 9, 2003 | 01:14 PM
ef9one6's Avatar
Default need some help!
ok so i just cleaned my engine with simple green i coverd every thing but i took my battery out to get the areas around it better when i put it back in smoke started comming out wtf???????????????????
its comming from here...
Modified by ef9one6 at 11:04 PM 12/9/2003
Modified by ef9one6 at 11:12 PM 12/9/2003
Modified by ef9one6 at 11:34 PM 12/9/2003
Old Dec 9, 2003 | 01:16 PM
Smokinsax's Avatar
The Boot
out of where?
RCautoworks's Avatar
Default Re: need some help! (ef9one6)
Smoke started coming out of where ?
Old Dec 9, 2003 | 01:20 PM
ef9one6's Avatar
it looked like it was coming from under the battrey but when i dsiconected it, it stopped
Old Dec 9, 2003 | 01:35 PM
Dry everything off really good, and reconnect everything.
Old Dec 9, 2003 | 01:44 PM
Donkey85's Avatar
Default Re: need some help! (90blackcrx)
when washing the motor always remeber to cover the intake filter and try to avoid spraying near the distributor and the alternator
Old Dec 9, 2003 | 03:21 PM
ef9one6's Avatar
its fixed thanks for all the advise
Old Dec 9, 2003 | 03:41 PM
redeyeef2's Avatar
That picture you show indicates that the starter wire grounded out on your starter. I would recommend double checking the clearance between the two.(just to be safe)
http://www.redeyefabrication.com
Old Dec 9, 2003 | 08:31 PM
cstem's Avatar
Default Re: need some help! (redeyeef2)
Replace that torched and corroded wire before it leaves you strand3ed or worse shorts and toasts the car.
Old Dec 9, 2003 | 08:34 PM
cottagecreep's Avatar
Default Re: need some help! (cstem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstem &raquo;</TD></TR><TR><TD CLASS="quote">Replace that torched and corroded wire before it leaves you strand3ed or worse shorts and toasts the car.</TD></TR></TABLE>
What he said, do something with that.
rocco
Feb 1, 2004 06:11 PM
92siracer
Jan 28, 2004 10:00 AM
mister_r0b
Dec 30, 2003 01:51 PM
ek_ctr
Dec 18, 2003 07:41 AM
d!zZy
Feb 11, 2003 03:21 PM
