MPFI swap questions...got it running but still need help
Old Dec 9, 2003 | 04:53 AM
neiche's Avatar
Default MPFI swap questions...got it running but still need help
OK here's the codes my ECU has 10/4/14 now here's my questions
I haven't reset the ECU yet
I have it running, sounds desent, but when I hit the throttle it boggs...haven't tried to drive it but it does rev when I smash pedal slow.
I put an ECAV from a B18, are they different? it fit but now I'm having the error code from there. I unplugged it and the error went away. weird
the tempature sensor might be bad but I can't get the screws out but i might be taking the intake back off to change it.
are there any way to test to make sure I'm getting good connection from the wires I added to the ECU?
Old Dec 9, 2003 | 04:59 AM
neiche's Avatar
Default Re: MPFI swap questions...got it running but still need help (neiche)
also my intake doesn't have the vaccum tube for vaccum #12 on the firewall.. and where does my old PVC tube need to go ...I have it sitting there.
Old Dec 9, 2003 | 09:26 AM
neiche's Avatar
bump....man this forum works fast !!!!! haha anyone?
Old Dec 9, 2003 | 10:20 AM
redeyeef2's Avatar
what color wires do you have on your ecav? IAT? code 4 is a distributor issue, did you run b10 b12 to existing c1 c2 and reroute new wires for c1 c2?
http://www.redeyefabrication.com
ggallinstyle
Jan 20, 2016 11:06 AM
bigdem1civic
Jan 22, 2012 01:26 PM
gt3hurman
Apr 13, 2005 07:54 PM
swappedb16teg
Feb 21, 2005 01:02 AM
Dark91zc
Oct 7, 2004 09:18 PM
