info on mini swap 88 crx si /d16y8 long block
just want some info about the part i need to do a mini swap on my 88 crx si i got a d16y8 long block from a 96 civic and im not sure if i need to rewire the ecu harness and if i can use the crx distributor and what do i need to buy i know i need a vtec controller thanks in advance
Modified by racenrockj06 at 5:28 AM 12/9/2003
Modified by racenrockj06 at 5:30 AM 12/9/2003
I recomend doing the full OBD 1 conversion.
P28 ecu
OBD 1 conversion harness(not needed but makes it real easy)
4 wire 02 sensor
obd 1 dist
DO it the right way and stay away from switch activated vtec.
P28 ecu
4 wire 02 sensor
obd 1 dist
racenrockj06
Dec 21, 2003 05:29 PM
turizmoj33
Dec 10, 2003 11:04 AM
