Fog Light problems??
Old Dec 8, 2003 | 06:59 PM
T-Mo's Avatar
Default Fog Light problems??
I have factory fog lights on my '92 Prelude Si and I am trying to figure out how to replace the bulbs (if there are bulbs) Anyone with this info help me out. I only have one working fog light.
Old Dec 10, 2003 | 11:28 AM
T-Mo's Avatar
Anyone?
Old Dec 10, 2003 | 01:27 PM
PhatboyNYC's Avatar
Default Re: (T-Mo)
You have to remove the fog assembly from the car to remove the bulbs. I believe one you have the foglight off, there are 4 screws that hold it together.
Old Dec 10, 2003 | 06:51 PM
MR.CLIFFORD's Avatar
Default Re: (PhAtBoY Si)
I agree There is also one screw holding the bulb in place once you take the casing off.
Old Dec 11, 2003 | 07:50 AM
yohan's Avatar
Unscrew the fog light bracket from inside the housing (take off the covers, remove all visible screws).
When you have the foglight housing in your hand, on the bottom of it where that rubber moister droppin thing is undo the 3 screws, theres a metal clip inside, the bulbs are H3.
Push down and move the clip and the bulb will pop out. Put the new ones in (dont touch the glass!!!!) and put it all back together.
Old Dec 11, 2003 | 08:42 AM
T-Mo's Avatar
What do you all suggest using to loosen the screws. I don't think that have been touched since '92 (13yrs) I tried using PB blaster but it's not budging.
Thanks for the replies so far though.
chiggin
Honda Civic (2006 - 2015)
Dec 5, 2007 02:09 AM
noss88
Jun 6, 2007 01:07 AM
MattyDA
Sep 1, 2005 02:50 PM
stiffiebdr
Mar 22, 2003 03:32 AM
