"gentle" 5th gear grind in h22 hatch.
Old Dec 8, 2003 | 06:03 PM
hondaeg5's Avatar
Default "gentle" 5th gear grind in h22 hatch.
its not that bad and doesnt happen all the time. i read a post on this once before,is it normal?? tried synchromesh,but no luck
by the way this is my eh2 vx only. the ek doesnt do it? maybee all the synchros are shott???
Old Dec 8, 2003 | 06:50 PM
Turbogixxer's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (hondaeg5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 &raquo;</TD></TR><TR><TD CLASS="quote">its not that bad and doesnt happen all the time. i read a post on this once before,is it normal?? tried synchromesh,but no luck</TD></TR></TABLE>
Make sure that it was the GM synchromesh with friction modifier. It is more money than the normal stuff. I have seen H22a swaps go hard in to 5th gear, but no grinds. I messed with the cables and it went away.
Old Dec 8, 2003 | 07:02 PM
hondaeg5's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (turbogixxer)
yes i got the right synchromesh. im gonna try messing with the cables. can the cables even go bad??? TIA
Old Dec 9, 2003 | 12:27 PM
Blaze45's Avatar
Brrraaaap!
The syncmch. didnt work for me, Untill about 1k after the change when I ran my car really hard.... Now I dont get grinds in ANY gear @ any RPM.....
Blaze
Old Dec 9, 2003 | 05:32 PM
double's Avatar
My car has the same exact problem just started last week.
I also tried the GM Synchromesh FM car still has the grind.
How many other H22 guys have this 5th gear grind?
I think my 5th gear synchro is crap.
Old Dec 9, 2003 | 07:29 PM
fastwanabe's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (double)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by double &raquo;</TD></TR><TR><TD CLASS="quote">My car has the same exact problem just started last week.
</TD></TR></TABLE>I dont have the 5th gear grind but I do have 3rd gear grind, I also tried the GM SM friction modifier but it still does it oh well.
Modified by fastwanabe at 2:44 PM 12/10/2003
Old Dec 10, 2003 | 03:23 AM
hondaeg5's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">The syncmch. didnt work for me, Untill about 1k after the change when I ran my car really hard.... Now I dont get grinds in ANY gear @ any RPM.....
Blaze</TD></TR></TABLE>
i havent put that many miles on it yet. maybee ill wait and see what happens.
Old Dec 10, 2003 | 06:08 PM
eg:R's Avatar
i have the same problem on mine also, 5th gear grinds, i have used gm synchromesh and redline mtf, it still grind, i just haven't try the friction modifier yet, i don't know if you would help,
Old Dec 11, 2003 | 10:54 AM
H22EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure that it was the GM synchromesh with friction modifier. It is more money than the normal stuff. I have seen H22a swaps go hard in to 5th gear, but no grinds. I messed with the cables and it went away.</TD></TR></TABLE>
As stated above try to adjust cables a little and make sure they are set right and there shouldn't be a problem. Make sure they are tight and don't have any slack in them.
Old Dec 11, 2003 | 01:49 PM
hondaeg5's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (H22EK)
can the cables go bad???? i have alot of play in the shifter while in gear.
Old Dec 11, 2003 | 03:37 PM
H22EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 &raquo;</TD></TR><TR><TD CLASS="quote">can the cables go bad???? i have alot of play in the shifter while in gear.</TD></TR></TABLE>
Well a little play is one thing, you need to get under the car and see if the cables are streched tight or what, yes cables can go bad in that they can starrt to fray or they can snap.
Old Dec 11, 2003 | 04:37 PM
h22dx's Avatar
i have both 3rd and 5th gear grind. 3rd only grinds if i'm really getting on it. in fifth however if i go from fourth, put it in neutral, let off clutch, and the push it back in and put it in fifth it doesnt grind at all???? synchro??
Old Dec 12, 2003 | 04:09 AM
ozzyman's Avatar
Default Re: "gentle" 5th gear grind in h22 hatch. (h22dx)
Also have the 5th gear grind. Just put in GM Syncromesh FM and feels ALOT smoother but still grinds every once in a while... usually at high rpms 3500+. If I shift around 3000 or lower then it wont grind. Ill just give it some more time and play with the cables a bit.
H22EK-
What should I do to 'play' with the cables?? Anything specific?? My cables seem to be pretty tight so I wouldnt know what to do or check for. TIA.
Old Dec 12, 2003 | 02:19 PM
AMeg6's Avatar
i have a tranny for sale if u decided that u need a new one
Old Dec 13, 2003 | 03:23 AM
ozzyman's Avatar
Default Re: (AMeg6)
bump
Old Dec 15, 2003 | 03:55 AM
hondaeg5's Avatar
Default Re: (AMeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMeg6 &raquo;</TD></TR><TR><TD CLASS="quote">i have a tranny for sale if u decided that u need a new one</TD></TR></TABLE>
which trans do you have? m2b4,m2a4?
clemsoncb7
Aug 5, 2012 01:33 PM
AznBlueBoy
May 29, 2007 03:45 PM
collapsedblkhrt
Mar 26, 2007 04:16 PM
r1de4life
Feb 14, 2006 01:21 PM
.BigSexy
Sep 26, 2005 05:16 AM
