Having probs with drivers side JDM low beam....
Old Dec 8, 2003 | 02:02 PM
P.O.H.'s Avatar
Default Having probs with drivers side JDM low beam....
the drivers side low beam (H4) is going out.... if I turn on my lights & the low beam turns on ..then I'm fine (if I leave them on). But some times if I turn them on (& they work) and turn then off and on... they don't work. The other night I was pulling out of my drive way and I noticed that the drivers side headlight got Brighter.... on it's own, for about a second or two... I know the H4's are dual filament (for high & low) so I'm guessing the H4 on the drivers side is swapping low to high on it's own... but I didn't use relay's for the dual filament... so it should only be the low beam turning on..... (this situation only happens every now & then)
Any one else have this problem???? Let me know... thanks.
Ceasar
Preludes Of Houston
Old Dec 10, 2003 | 12:42 PM
P.O.H.'s Avatar
Default Re: Having probs with drivers side JDM low beam.... (P.O.H.)
I guess I'm the only one with this problem
Ceasar
jonny11844
Feb 23, 2014 05:14 PM
sanggggiee
May 23, 2012 06:09 PM
93formula
Nov 24, 2008 11:52 PM
rezzarect
Jul 28, 2007 08:22 AM
monalisa overdrive
Nov 7, 2004 02:20 PM
