Piston speed: What determines this, and how to calculate?
Old Sep 18, 2001 | 08:47 PM
HXMan's Avatar
Default Piston speed: What determines this, and how to calculate?
I was kinda curious.
Does piston speed only depend on RPMs and stroke length? Does rod length affect speed, or piston acceleration? Or both?
What is the formula for calculating piston speed? What does it take into account? Stroke length, rod length, engine speed?
I would really like a formula to play around with.
Thanks in advance!
Old Sep 19, 2001 | 12:46 AM
Gasoline Fumes's Avatar
Default Re: Piston speed: What determines this, and how to calculate? (HXMan)
Average piston speed would only be effected by rpm and stroke.
Old Sep 19, 2001 | 04:03 AM
il8apex's Avatar
New User
Default Re: Piston speed: What determines this, and how to calculate? (Gasoline Fumes)
I'm looking for a formula, will let you know when I find it.
-Tom
[Modified by il8apex, 1:33 PM 9/19/2001]
Old Sep 19, 2001 | 04:33 AM
il8apex's Avatar
New User
Default Re: Piston speed: What determines this, and how to calculate? (il8apex)
The graph is roughly a sine wave (~).
Anyway, I can't find a formula for piston speed at a given crank position, but I think you can use the following to determine max. piston speed for a given rmp. (Disclaimer: I just wrote this from memory, so please someone correct me!)
Use the crank stroke as "S", and "~" equals Pi because there isn't a Pi character on the keyboard! Dividing by 60,000 changes mm / minute to meters / second.
RPM x (~S)
60,000
So, if your stroke is 81mm and you're running 7500rpm, your piston speed is 31.8086 meters/second. Hope this helps!
-Tom
Old Sep 19, 2001 | 06:48 AM
HXMan's Avatar
Thanks....now if I can just figure how to graph that with my computer.......
dart2.2
Jan 16, 2007 11:26 AM
95lstegman
Nov 24, 2005 07:27 PM
91integraLSVTEC
Feb 15, 2004 03:53 PM
Zeus Zore
Oct 4, 2002 07:50 AM
HXMan
Sep 27, 2001 12:15 PM
