Noise from cam gears?
Old Dec 8, 2003 | 10:08 AM
Asahi's Avatar
Default Noise from Cam gears
I coudl be mistaken but this morning I hard a strange rattle/jingling noise from the engine. Opened the hood and it sounds as if the cam gears have a jingle to the, They are Toda Gen 1 Cam gears. This strated after I adjusted them this weekend.
I am more than positive all 4 bolts on each gear are tight. Does anyone have any suggestions as to what might eb the problem? Could the timing belt need more tnesion?
Trey
Old Dec 8, 2003 | 12:57 PM
Ferrell's Avatar
Default Re: Noise from Cam gears (Asahi)
check to see if the timing belt is rubbing that plastic trim under the gears. I noticed mine did the same, and there was frequent black residue on the gears and misc other things.... might not be much help, but thats what I saw on mine. Goodluck Trey
Old Dec 8, 2003 | 09:03 PM
TyPe_R_GuY's Avatar
Well did you leave off the upper timing belt cover when you adjusted your cam gears? cause mine is off and when my car is cold and i start my car, it like rattles, and its the timing belt
Old Dec 9, 2003 | 12:15 AM
cheezthis's Avatar
I don't have experience w/those, but I have experienced similar noises from other cam gear sets before. Nothing ever really happened w/them though. Just double check everything is torqued right and that the belt is on a clear path. You'll know if they're loose, trust me...your car will tell you.
cooteg6
May 9, 2006 03:12 PM
doublejz
Nov 12, 2005 03:06 PM
HamiltonRex
Nov 13, 2004 05:50 PM
acatak
Apr 29, 2003 10:41 AM
The-LS
Apr 17, 2003 01:34 PM
