sleeving process?
when getting your block sleeved, are the sleeves installed using a special press or something? or are they heated in an oven to the point where they get hot enough for the sleeves to just slide in?
best way to do it is by heating your block up and having new ones to slide in.this process assures that your sleeves will not end up sliping down under stress. this is based from experience and what rs told me .
What did we tell you???? Heating up the block is something that we do not do to install sleeves.......The hottest that the block gets around here is when it is in the hot tank getting cleaned!!!!!!!! And yes we do have RS Magnum Pro(closed deck) Sleeves for the D series!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hob20hb »</TD></TR><TR><TD CLASS="quote">best way to do it is by heating your block up and having new ones to slide in.this process assures that your sleeves will not end up sliping down under stress. this is based from experience and what rs told me . </TD></TR></TABLE>
