Types of brake fluids?
Old Dec 8, 2003 | 06:38 AM
vabchaccord's Avatar
Default Types of brake fluids?
I'm considering getting my brake system flushed and refilled at some shop, but are there synthetic brake fluids like there are synthetic motor oils and are they worth it? How much might a dealer charge for the flush and fill and would it be worth it to use the synthetic stuff (if it exists) or just Honda's brake fluid? Not changing any parts, just want to replace the fluid.
Old Dec 8, 2003 | 06:51 AM
KGAccord's Avatar
Default Re: Types of brake fluids? (vabchaccord)
valvoline makes a good brake fluid, but i used ATE super blue which one of the best besides motul.
Old Dec 8, 2003 | 06:59 AM
What's the capacity of a 97 EX's brake system, roughly?
Old Dec 8, 2003 | 07:25 AM
KGAccord's Avatar
Default Re: (vabchaccord)
not very much, ATE stuff is sold in 1 liter bottles and i have atleast 1/2 -2/3 left. if you buy honda fluid or valvoline just get 1 of those little bottle, a pint i believe.
Old Dec 8, 2003 | 09:26 AM
iam7head's Avatar
Default Re: (KGAccord)
use DOT oem dot 4(oil based)
I heard there's dot 5.1 can be used with abs equiped car.
upper boiling point, wont absorb water(silicone based), all that good stuffs.
cant use 5.0 with abs pump tho'
Old Dec 9, 2003 | 05:55 AM
JimBlake's Avatar
Default Re: (iam7head)
DOT 5 is based on silicone, but DOT 5.1 is NOT. I think it's a poly-glycol like DOT 3 & 4.
Old Dec 9, 2003 | 09:51 PM
iam7head's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">DOT 5 is based on silicone, but DOT 5.1 is NOT. I think it's a poly-glycol like DOT 3 & 4.</TD></TR></TABLE>
so 5.1 is still a smart upgrade?
thanks for cleaing that up
Old Dec 10, 2003 | 03:58 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">so 5.1 is still a smart upgrade?</TD></TR></TABLE>I don't know, I'm not sure I can actually clear this up. I haven't seen anything labeled 5.1 on store shelves...
I heard Valvoline SynPower was a 5.1 synthetic that happened to satisfy 3 & 4, so it's labeled as DOT 3 & 4. I'm not even sure that's true because I can't find anything to verify that statement. Apparently 5.1 requires lower viscosity, and 3/4 don't actually prohibit the low viscosity.
I tried SynPower, but I had some troubles with it. I suspect the low viscosity because I got a squeaking sensation in my clutch like the MC & SC piston seals weren't being lubricated. I went back to Castrol LMA on the Accords & I tried ATE Blue on the GS-R & Saab.
bigsyke
Suspension & Brakes
17
Jun 23, 2008 08:22 PM
216.226.142.95:27016
Jul 22, 2004 04:17 AM
CivicSiRacer
24
May 15, 2003 12:03 PM
jdm92accord
Jan 30, 2002 09:29 AM
