Maintance and Tune up
I purchased a 93 Prelude with DOHC VTEC, Was just checking to see if there is anything I should do like tune up. The car had a 129,000 miles on it and the owner had no idea what has been done to it. So here is what I have done so far Had the Timing belt replaced, replaced the Sparkplugs, cables look good Had the radiator hoses replaced and radiator flushed.
I was thinking about the fuel filter, can someone tell me were it's located?
Anything else I should be replacing?
Thanks Dave
Thanks Dave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlude »</TD></TR><TR><TD CLASS="quote">
Thanks Dave
it's mounted on the firewall,
did you change the water pump
when you got the tb replaced?
Thanks Dave
They took care of the water pump for me, I have done the oil change. I will check on the Tran Fluid change. I will get a new Fuel filter this weekend.
Thanks Dave
Thanks Dave
Don't forget spark plug wires, new distributor rotor. I do that every three years regardless of the miles. Be carefull on the wires. I bought a set of NGK wires, had them tested for resistance. They were worse than the Neuspeed wires I was going to replace. Left the Neuspeed wires on. High resistance wires leave less spark in the combustion chamber.
Spider Man
Dec 15, 2005 12:32 AM
dman81
Mar 9, 2005 01:51 PM
