engine swap
i have a b16 in an ek with 99-00 si ecu and 99-00 si engine harness. im wondering why my car will crank but not able to start. when i put a jdm type r ecu in it will start and run but theres check engine light. so please let me know if you have an idea of what is wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goofy racer »</TD></TR><TR><TD CLASS="quote"> im wondering why my car will crank but not able to start. when i put a jdm type r ecu in it will start and run. </TD></TR></TABLE>
U confussed me here what are you trying to do?
did put in the JDM ITR ECU and it wont crank/start?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 »</TD></TR><TR><TD CLASS="quote">
did put in the JDM ITR ECU and it wont crank/start?</TD></TR></TABLE>
no, the 99-00 Si ecu = doesn't start
jdm itr ecu = starts
as in why one ecu starts the car and the other doesn't? *shrugs shoulders*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">
as in why one ecu starts the car and the other doesn't? *shrugs shoulders*</TD></TR></TABLE>
in that case
99-00ECU =
(Bad ECU)
JDM ITR ECU =
(Good ECU)
what code are you getting from the ITR ECU?
in that case
99-00ECU =
(Bad ECU)JDM ITR ECU =
(Good ECU)what code are you getting from the ITR ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">yeah, that just means the si ecu is defective.</TD></TR></TABLE>
Check to make sure, i'm not 100% possitive but the 99-00 si ecu may have the imobilizer chip in it. My 2000 ls (p75) had that chip and would do the same thing. Check with honda, and if so you can just take the chip out.
Not sure if this has anything to do with anything but I'm having issues starting my car. It has a JDM B18C OBDI in it with JDM computer. Issue just started but the check engine light's been on since I did the swap almost two years ago. I haven't tried a USDM computer yet to see if it works but methinks there is definitely a difference between JDM and USDM.
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
