HELP: installing ARP extended lug!
Old Dec 7, 2003 | 09:07 PM
95-EJ1's Avatar
Default HELP: installing ARP extended studs!
I was wondering if I have to replace my front wheel bearings when installing the ARP extended wheel studs...please help!!
Modified by [626] 95-EJ1 at 6:41 PM 12/8/2003
Old Dec 7, 2003 | 09:49 PM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! ([626] 95-EJ1)
can n e one help...
Old Dec 7, 2003 | 11:04 PM
aira
Guest
Posts: n/a
where did you get them at? i plan on doing this, but don't know where to buy em. sorry i can help you.
Old Dec 8, 2003 | 07:53 AM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! (aira)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aira &raquo;</TD></TR><TR><TD CLASS="quote">where did you get them at? i plan on doing this, but don't know where to buy em. sorry i can help you. </TD></TR></TABLE>
I got them from a buddy who has a shop out by where i stay...but, there's a guy on here that sales them...i can't remember his sn though.
Can n e one help me out??????????
Old Dec 8, 2003 | 07:58 AM
ek four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote"> 95-EJ1]I was wondering if I have to replace my front wheel bearings when installing the ARP extended wheel studs...please help!!</TD></TR></TABLE>
nope. i just had my studs removed and replace. nothing else was necessary.
Old Dec 8, 2003 | 09:40 AM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! (ek four)
ohh...coo, n e one else?
Old Dec 8, 2003 | 09:44 AM
opi's Avatar
opi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek four &raquo;</TD></TR><TR><TD CLASS="quote">
nope. i just had my studs removed and replace. nothing else was necessary.</TD></TR></TABLE>
yep, he's right...but you might want to check the bearing, but other than that, all you have to do is replace the studs...good luck
Old Dec 8, 2003 | 12:56 PM
nerdsports's Avatar
Default Re: HELP: installing ARP extended lug! (opi)
how did u guys remove and install them? i'm going to get a set soon too. and when i put in regular replacements, i had a hardtime! longer ones would sure ruin my day!!! i searched
Old Dec 8, 2003 | 12:59 PM
FifthGearOnline's Avatar
Default Re: HELP: installing ARP extended lug! (nerdsports)
have them pressed in and out
Old Dec 8, 2003 | 01:05 PM
93civicEX's Avatar
Default Re: HELP: installing ARP extended lug! (FifthGearOnline)
Pressing them is the correct way, But if you do not have access to a press, i'm pretty sure you can take a 5 pounds sledge and hit them out. and then hit the back of the stud to get them back in
Old Dec 8, 2003 | 01:49 PM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! (93civicEX)
where can i get them pressed at???
Old Dec 8, 2003 | 03:36 PM
Bnjmn's Avatar
any time you press out the hub you should replace the bearings since the process of pressing the bearing out can mess up the bearing. Or you can take your chances.
Ben
Old Dec 8, 2003 | 04:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote"> 95-EJ1]where can i get them pressed at???</TD></TR></TABLE>
any local repair shop can
Old Dec 8, 2003 | 06:46 PM
nerdsports's Avatar
do you really have to press the hub out and back in just for extended lug studs?? damn... seems like more work that i thought!
Old Dec 8, 2003 | 07:00 PM
Cheivic's Avatar
What year car? I installed regular size studs by myself. I had to dremel some of the back of the hub off just to barely get the regular size studs in.
I wish I would have just had a shop do it. Would have saved me time and frustration in the long run. I don't beleive the bearings are repackable. So I would recommend that you get new ones. BTW, they're very expensive.
Edit**: To give you an idea of what I did. Here's a pic. I added a couple stuff to the original.
If you have any questions feel free to IM me.
Old Dec 8, 2003 | 07:07 PM
H22ek4's Avatar
http://www.summitracing.com its like $12 for 5 studs
Old Dec 8, 2003 | 07:44 PM
hellogoodbye's Avatar
Default Re: HELP: installing ARP extended lug! (H22ek4)
sand down the end side of the stud. this will make it easier for it to slide into the hub. hopefully you have a press to get it thru
Old Dec 8, 2003 | 07:59 PM
LSVTECoupe's Avatar
Default Re: HELP: installing ARP extended lug! (tekneek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneek &raquo;</TD></TR><TR><TD CLASS="quote">sand down the end side of the stud. this will make it easier for it to slide into the hub. hopefully you have a press to get it thru</TD></TR></TABLE> i did this and also grinded the side of the hub cause the extended wheel stud wouldn't fit.. this way you don't have to have the wheel bearing pressed out.
Old Dec 8, 2003 | 08:45 PM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! (LSVTECoupe)
niiice....this info is helpful....thanxs guys. Keep them comin' if u like!
Old Dec 8, 2003 | 09:09 PM
99blackcivicSi's Avatar
I always recomend replaceing your wheel bearings when you do this i just put extended studs in my car and replaced the wheel bearings might as well do it while your in there kinda like doing a timing belt you might not NEED a water pump but you do it anyways ya know what i am saying? put in new wheel bearings just in case they are damaged which there is a good chance they will be when you pull the hub apart from the spindle
Old Dec 8, 2003 | 09:14 PM
95-EJ1's Avatar
Default Re: HELP: installing ARP extended lug! (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">I always recomend replaceing your wheel bearings when you do this i just put extended studs in my car and replaced the wheel bearings might as well do it while your in there kinda like doing a timing belt you might not NEED a water pump but you do it anyways ya know what i am saying? put in new wheel bearings just in case they are damaged which there is a good chance they will be when you pull the hub apart from the spindle </TD></TR></TABLE>
how much does wheel bearings go for n e ways??
Old Dec 8, 2003 | 09:47 PM
95-EJ1's Avatar
bump!
Old Dec 9, 2003 | 12:00 AM
Mr. Choi's Avatar
New User
i htink wheel bearings are like 25-30. if you have high mileage on your car it wouldnt hurt
changing them.
Old Dec 9, 2003 | 04:27 AM
slammed_93_hatch's Avatar
Default Re: HELP: installing ARP extended lug! (Mr. Choi)
are all wheel bearings the same or are they different for each car.
EX
im getting 96 ITR suspension and going to be adding extended studs, can i just get a wheel baring for my 93 civic or what do i do
Old Dec 9, 2003 | 05:53 AM
ek four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneek &raquo;</TD></TR><TR><TD CLASS="quote">....</TD></TR></TABLE>
tekneek, you stole my avatar
