Any one using Vision One Touch Seatslider for their JDM Recaros?
Old Sep 18, 2001 | 06:30 PM
machgo5go's Avatar
Default Any one using Vision One Touch Seatslider for their JDM Recaros?
Hi,
I want to lower my JDM recaros in my ITR. Anyone using these Rails and how they fitted?
And where did u order them from and how much? Thanks for all replies.
ed lee
Y2K ITR #498
97 ITR #315 RIP
Old Sep 18, 2001 | 07:31 PM
Racer-X's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (machgo5go)
The Vision one touch slider seat rails are made by recaro so there should be no problem in fit ment. For the seating hieght I wouldn't be sure as there made to be used to work with there corsa CF seats. They have lower bracket set that works with there seat not sure if or how it would work with normal JDM recaros as they don't mention it being made by them.
I can get you a set if you like just email me. I will get price on it for you.
Old Sep 18, 2001 | 09:11 PM
Benjamin Tang's Avatar
i have them. it's just a set of recaro sliders with mounting tabs welded to it. there is no bracket like wedge or similar. if u are 5'4" or 5'6" or so don't bother because u won't be able to see over the steering wheel. i'm 6'2" and i have problems sometimes. but if u are over the min. and have helmet clearance problems this is it.
they are also lighter than stock
Old Sep 19, 2001 | 02:33 AM
machgo5go's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (Benjamin Tang)
Thanks all,
I am just 5'5 so from your experiences, i dont really need them. It just after i installed the JDM Recaros, it just look higher then the oem USDM seats. Actually i have no problem with them. I just thought its better with oem heights.
ed lee
Old Sep 19, 2001 | 03:09 AM
Dee's Avatar
Dee
hmmm.... grrrrr....
Vision one touch rails.. Are those in the pic CTR or ITR? Sorry guys! Ben knows why I'm growling!
Old Sep 19, 2001 | 03:18 AM
Zeus's Avatar
Ben, got a pic of you in the seat? I'm 6'1" but "sit tall" and was wondering if that might be right for me...
Old Sep 19, 2001 | 05:38 AM
R1020's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (Zeus)
i have those rails as well. it made the seat more 'flat', or parallel to the ground, instead of leaving back a bit with the JDM OE rails.
so, i stuck about 4 washers in between the seat and the rails where they bolt together in the front of the seat. that helped a bit, but now the seat shifts a little under hard braking . . . which makes sense because the outside rail doesn't lock, but it did NOT shift before i installed the washers.
the rails are nice, but the quality and fitment isn't quite up to par with the JDM OE rails. it did also take me a little while to get used to sitting so low, too.
my $0.02.
Old Sep 19, 2001 | 06:30 AM
XR4racer's Avatar
I wish I could make these work on my Sparco EVO2s... Anybody tried? The EVO2s are side mount, but I have the Sparco L brackets, which might work, but I would have to know they would work before i buy anything else.. I already have a pile of various sliders,brackets, and hardware which didn't work in the floor at the house.
Old Sep 19, 2001 | 07:23 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (XR4racer)
How much and will they work with Sparco Torinos?
Old Sep 19, 2001 | 08:17 AM
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (itr009)
i believe the sliders in the picture are for ek9, but the difference is only in one mounting plate.
these rails were meant for recaro sr-style seats. if u have another brand that uses the same mounting points as a recaro sr, then yes i don't see why they wouldn't work. otherwise... no.
Old Sep 19, 2001 | 09:48 AM
STOLEN - ITR 98-0652's Avatar
Hunh?
Are you telling me these will lower the seat height? ...and it's significant?
Old Sep 19, 2001 | 10:13 AM
R1020's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (ITR 98-0652)
vision makes two models, the 'low' (-1") and 'super-low' (-1.5"). i have the super-low and it's pretty damn low.
peter
Old Sep 19, 2001 | 12:12 PM
Akira-R's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (R1020)
I have them. It feels like i'm in a go-cart.
They do make it flatter. I haven't dont the washer trick yet.
It's a bitch to slide back and forth on mine. For some reason the rails kinda "bend"
over the mounting points. And it doesn't slide smoothly. But once you have them set, you shouldn't
need to move them anyways.
--reid
Old Sep 19, 2001 | 07:27 PM
machgo5go's Avatar
Default Re: Any one using Vision One Touch Seatslider for their JDM Recaros? (Akira-R)
Well, thanks for all your inputs!
I stick with my jdm oe rails. (works and save money)
ed lee
Old Sep 26, 2001 | 03:42 PM
XR4racer's Avatar
Anybody Have a Line on these things yet? Where can I get them and How Much?
Old Sep 26, 2001 | 03:48 PM
Dee's Avatar
Dee
Try AJ racing in Canada .....
MomoInteg
Mar 1, 2008 04:42 AM
Fabfive
Sep 6, 2005 12:03 PM
Mr.Fairlady
Jul 10, 2004 11:06 AM
JDM TypeR 307
Jan 23, 2004 01:19 PM
Rhetoric
Nov 2, 2003 03:08 PM
