For those with Coilovers ?? about alignment
Old Sep 18, 2001 | 06:16 PM
Ghetto Racing's Avatar
New User
Default For those with Coilovers ?? about alignment
How much is your R lowered from stock and....
What are your alignment numbers toe, total toe, caster, camber, thrust angle etc..
For all that's relevent Frt & Rr.
Also, if the camber is off more on one side than the other and you use a camber kit to "even it out" would your thrust angle be off?
i would really appreciate it.
Thanks in advance guys
Old Sep 18, 2001 | 08:22 PM
ajbones's Avatar
New User
Default Re: For those with Coilovers ?? about alignment (F1 Soul)
I had tein HA installed not too long ago on my GSR. They are at the lowest setting. Preety low. About the same as Mike K's car on his present post. I had the car aligned yesterday. They were not able to get the specs i was hoping for, but here is what they came up with.
front left
camber; -1.79
caster: 0.36
toe' 0,11 in.
front right
camber; -2.37
caster; 0.79
toe; 0.12 in.
left rear
camber; -1.80
toe; 0.06 in
right rear
camber; -1.7
toe; 0.03 in
front
cross camber; 0.61
total toe; 0.22 in.
rear
cross camber; -0.3
total toe; 0.10 in
thrust angle; 0.03
I think i am going to get a camberkit, and perhaps raise it a bit also.
I do not totaly understand all the numbers, but.....
[Modified by ajbones, 9:23 PM 9/18/2001]
Old Sep 18, 2001 | 09:25 PM
Benjamin Tang's Avatar
Default Re: For those with Coilovers ?? about alignment (ajbones)
front left
camber; -1.8
caster: 0.5
toe: 0.00'
front right
camber; -1.6
caster; 0.00'
toe; 0.12 in.
left rear
camber; -1.7
toe: 0.15'
right rear
camber; -1.7
toe; 0.15'
front
cross camber; ?
total toe: 0'
rear
cross camber; ?
total toe; 0.30'
thrust angle; 0'
car is running front camber kit. washers in rear. lowered over 2"
Old Sep 19, 2001 | 03:35 AM
COREY ITR#625's Avatar
Default Re: For those with Coilovers ?? about alignment (Benjamin Tang)
Since we are on the subject.....I have had my N-1's for a while now and I had a Ingall's camber kit on the front. It seems after I got the kit put on, the upper control arms were hitting under the fender. I could not tell it was doing this though.
My car is not low at all. I can get about two fingers in between the tires and the fender. I noticed this when I opened mt hood after washing my car one day and noticed by where the shock comes out the top that the paint was flaking off. It looks like there is something pushing up from the bottom. I didn't notice this until after I got the camber kit. Is it possible that my car was to low at the time (I since then raised it up) and when they adjusted the camber, it pulled the upper control arm out more and caused it to hit it? Anyone else have this problem?
Old Sep 19, 2001 | 04:50 AM
New User
Thanks Guys,
I wondering if any can supply #'s based on a 1" lowering from stock?
Old Sep 19, 2001 | 04:54 AM
BABY NSX's Avatar
Has anyone done an alignment after installing Mugen Lowdowns (0.75" drop)?
Old Sep 19, 2001 | 05:38 AM
RaVAGE00's Avatar
New User
Default Re: For those with Coilovers ?? about alignment (BABY NSX)
Not yet... but I will let you know in one weeks time...
By the way what happen to the timing job?
Old Sep 19, 2001 | 05:48 AM
Edwin's Avatar
front left
camber; -1.82
caster: 0.59
toe: 0.2mm
front right
camber; -1.6
caster; 0.76'
toe; 0.6mm
left rear
camber; -1.36
toe: 0.6mm
right rear
camber; -1.69
toe; 0.6mm
front
total toe: 0.8mm
rear
total toe; 1.2mm
thrust angle; 0
Car is lowered 1.4 inches
[Modified by Edwin, 2:53 PM 9/19/2001]
Old Sep 19, 2001 | 05:50 AM
R1020's Avatar
Default Re: For those with Coilovers ?? about alignment (RaVAGE00)
my car is lowered about 1.5" below stock.
i don't remember my toe and castor, but i believe that they're within spec.
my camber is about -2.1 degrees in the front and about -2.0 in the rear. i had a pretty decent alignment done and my tires are wearing fairly well.
[Modified by R1020, 9:51 AM 9/19/2001]
Old Sep 19, 2001 | 06:15 AM
RaVAGE00's Avatar
New User
Default Re: For those with Coilovers ?? about alignment (R1020)
Hey Edwin you drive a R... take that Supra doing a 4 wheel drift off your AVATAR!
Old Sep 19, 2001 | 06:22 AM
98itr896's Avatar
yes. for street setup you can get stock numbers for everything except the camber. stock i believe is -1 and with the lowdowns you can only get -1.5 degree. this is with 16" wheels.
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
bopbop93030
Apr 6, 2008 08:32 AM
austrian type-R
Jul 23, 2003 07:42 AM
alfaaay
Mar 21, 2003 06:30 PM
yoshi234
Dec 27, 2001 01:11 PM
