Camber Kit for SH
Old Dec 7, 2003 | 08:04 PM
Wiseguy619's Avatar
Default Camber Kit for SH
I have done a search for this, but many of the post are pretty old. I was wondering what camber kits are being used on the SH's in the forum. I will be getting some tein ss soon, so I'm pretty sure I'll be needing to adjust my camber.
Old Dec 7, 2003 | 11:36 PM
743's Avatar
743
Default Re: Camber Kit for SH (ProjectPenny)
As long as you have your toe adjusted your camber shouldent wear too crazily.
Old Dec 8, 2003 | 09:36 AM
Wiseguy619's Avatar
Default Re: Camber Kit for SH (-743-)
I wanted to intall the coilovers myself, but I have read that it should be done at a shop because they have the equipment to jack each wheel while the car is in the air so that the suspension is properly adjusted. Correct me if I am wrong. Also, would they adjust the toe with installation? With a camber kit, I would not have to worry about wear at all, so wouldn't it be worth it?
Old Dec 8, 2003 | 09:55 AM
bad-monkey's Avatar
the reason why lowered cars usually experience accelerated tire wear is because of toe issues. after you install the SS, take it to a shop and get it aligned. what you're looking for is 0 toe. the most common rule i hear on the net (so take it with a grain of salt) is that cars lowered up to 1.5" do not need a camber kit.
hatch_
Feb 10, 2009 09:25 PM
FLACO EM1
Nov 27, 2008 01:39 PM
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
00accordguy
May 21, 2006 09:33 AM
dom93hatch
Apr 19, 2003 10:26 PM
