One quick VTEC wiring question! then mad VtEc y0!
Old Dec 7, 2003 | 06:48 PM
Sketch_hs's Avatar
Default One quick VTEC wiring question! then mad VtEc y0!
Okay so i got everything figured out but one little thing
There is already a wire going into the A4 plug (Black) where the vtec pressure switch (blue) wire is supposed to go...
cut it? or what?
where does that wire that's already in there go?
car is a 93 DX, swapping a OBDI B16a2 motor in there.
THANKS!
Old Dec 7, 2003 | 06:56 PM
jdmsiR20's Avatar
Default Re: One quick VTEC wiring question! then mad VtEc y0! (Sketch_hs)
when looking at the ecu, plug a4 should be orange/white... that goes directly to the vtec solenoid... whatever that black one is doing there, it shouldn't have been from the factory... are you sure you are looking at a4?
Old Dec 7, 2003 | 07:23 PM
HybriDNA's Avatar
Default Re: One quick VTEC wiring question! then mad VtEc y0! (jdmsiR20)
when looking at the clip with the wires don't look at the front part ....look at the back part where you can see the wires go into the clip... because if look it from the front you'll be counting the wires in the wrong direction.. got it?
Old Dec 8, 2003 | 08:45 AM
Sketch_hs's Avatar
Default Re: One quick VTEC wiring question! then mad VtEc y0! (HybriDNA)
i'm a dumbass and was looking at it wrong, thanks!
Old Dec 15, 2003 | 06:33 AM
rebohn's Avatar
what i need how many wires neeed the selenoid only have one wire, yellow/green other one blue and ground ? ok i know yellow green to a6 in ecu the blue in pin d6 right and other cables red a20? where add? purge selenoide purge oil pressure
please somebody have step by step i dont understand all people help me with pin out but i dont know what i can do with others wires
please help me
Old Dec 15, 2003 | 09:25 AM
Sketch_hs's Avatar
Default Re: One quick VTEC wiring question! then mad VtEc (rebohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebohn &raquo;</TD></TR><TR><TD CLASS="quote">what i need how many wires neeed the selenoid only have one wire, yellow/green other one blue and ground ? ok i know yellow green to a6 in ecu the blue in pin d6 right and other cables red a20? where add? purge selenoide purge oil pressure
please help me</TD></TR></TABLE>
yellow/green goes to A6
Blue Goes to D6
i didn't wire the knock sensor cause i'm running the P28 mugen ecu
Old Dec 19, 2003 | 07:46 AM
rebohn's Avatar
ok i get vtec connected thanks for your help nice experience am glad
Old Dec 19, 2003 | 08:05 AM
slammed_93_hatch's Avatar
Default Re: One quick VTEC wiring question! then mad VtEc (Sketch_hs)
so you got the mAd!!! v--tech's Yo!!
Old Dec 19, 2003 | 08:16 AM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebohn &raquo;</TD></TR><TR><TD CLASS="quote">ok i get vtec connected thanks for your help nice experience am glad
m4D Th1rD G34R VTeC, Y0!
jdmwojo
Dec 10, 2010 11:07 AM
Acidcrakker
Nov 8, 2007 02:39 PM
Crimson_Tide
Jul 29, 2005 03:18 PM
im a monster hehe
Dec 24, 2003 11:12 PM
