Racing Harnesses
Old Dec 7, 2003 | 05:19 PM
EF4lyfe's Avatar
Default Racing Harnesses
I have JDM recaro ITR seats, and was thinking about buying four-point harnesses to mount onto my seat brackets, is this bad? I heard that if i dont make the pressure even and dont mount it onto a roll cage or back of the car frame, then i can snap my back if i get into an accident because the harnesses are bolted straight down below the seat?????
Old Dec 7, 2003 | 06:08 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Racing Harnesses (SIhatch90)
Do not install a racing harness unless you have a roll bar or roll cage.
This has been discussed several times.
If you want to find out more about it do a search about harnesses here and make sure to include archived content.
Old Dec 7, 2003 | 08:08 PM
CRX-RX's Avatar
Default Re: Racing Harnesses (The new Spaceballs)
Harness = Cage. One exception would be if you wanted to run them for autocross to stay in your seat, since you are not likely to another vehicle. That's pretty much the intention of the base mounted harness, not for use on the streets, you would still retain your stock belts.
Old Dec 7, 2003 | 09:21 PM
bseriesboosted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">Do not install a racing harness unless you have a roll bar or roll cage.
If you want to find out more about it do a search about harnesses here and make sure to include archived content.</TD></TR></TABLE>
exactly
https://honda-tech.com/zerosearch
96jdm-ek
Welding / Fabrication
May 16, 2011 08:09 AM
B33R
Mar 3, 2006 10:46 AM
AutoEuphoria
Feb 9, 2005 12:46 PM
Blindstuff
Feb 8, 2004 02:34 PM
MintyDip
36
Jul 13, 2002 11:48 AM
