B18C5 into 96 civic dx hatchback
Old Dec 7, 2003 | 05:12 PM
DA6righthand's Avatar
Default B18C5 into 96 civic dx hatchback
i was lookin into doing a jdm type r swap into a 96 civic dx hatch. ive found the motors for around 6k, with 10-20 thousand miles, hydralic trans, ecu, obd-2 harness,sensors, and axles. what else do i need to complete the swap? do i need to shorten the axles, i heard the integra axles were longer than civics cuz tegs were wider, but that was on an 89 hatch. ive also read that the motor was a direct fit into a 6g civic, except for the rear mounts. i dont kno what mounts i should use, or any clue on how to hook up the ecu. anyone whos done this swap, lemme kno how you did ur swap. and do you need to take off the transmission to pull the motor out? also is there a page or book on ECU's for dummies that i could read up on? please help, any input is appreciated
Old Dec 7, 2003 | 05:44 PM
Default Re: B18C5 into 96 civic dx hatchback (nohondayet)
and what about the tachometer? how do i get one that is in the dash instead of the bigass tachs that look like ****(just my opinion). do i just buy a type r gauge cluster? please help me
Old Dec 7, 2003 | 06:30 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">and what about the tachometer? how do i get one that is in the dash instead of the bigass tachs that look like ****(just my opinion). do i just buy a type r gauge cluster? please help me</TD></TR></TABLE>
You could get a gauge cluster from a 96-98 EX, 99-00 Si or 97-00 CRV. You could also get a JDM CTR cluster or variations of the Euro EK if you don't mind reading your speed in KMH.
Old Dec 7, 2003 | 06:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">what else do i need to complete the swap? do i need to shorten the axles, i heard the integra axles were longer than civics cuz tegs were wider, but that was on an 89 hatch.</TD></TR></TABLE>
The Integra axles are a direct fit to the 6th gen. The only time you would run into trouble would be with the JDM ITR axles (98+ I think) that have a larger diameter outer joint shaft and splines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">ive also read that the motor was a direct fit into a 6g civic, except for the rear mounts. i dont kno what mounts i should use</TD></TR></TABLE>
You will need a 99-00 Civic Si rear mount bracket and also a driver's side mount bracket. The rest will be a mix of stock and Integra brackets and mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">or any clue on how to hook up the ecu.</TD></TR></TABLE>
Depending on which ECU you get, it should plug directly into your harness. Usually the most you would have to do is buy a specific OBD adapter harness. Of course there will be some wiring involved since there are going to be some extra sensors to wire up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also is there a page or book on ECU's for dummies that i could read up on? please help, any input is appreciated</TD></TR></TABLE>
At the very least, go to a parts store (Autozone, Pepboys, etc.) and buy a Helms manual that cover's 96-00 Civic's and 94-01 Integra's. These may not contain all the nice things that a Helms manual does, but at a small fraction of the cost they cover enough to get you by. Don't forget to search here, as many of the questions you've asked or will ask have already been covered.
Old Dec 9, 2003 | 03:45 PM
Default Re: B18C5 into 96 civic dx hatchback (VTECVillain)
the engine i was wanting to get came with the OBD-2 harness. i also read on the hybrid honda forum that you have to add some sensors that arent already there. my other question is the resline of the CTR and ITR are the same? didnt kno that. learn something new everyday. and also the motor i was gonna buy was jdm, and it says it comes with axles, and im assumming that they are also jdm, wil ihave to shorten those? how much would that cost? or would i be better off just gettin different shafts, like maybe stock CTR axles or high perfmance axles?
Old Dec 10, 2003 | 04:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">the engine i was wanting to get came with the OBD-2 harness.</TD></TR></TABLE>
2 things won't allow you to reuse the harness that comes with the motor: 1.) It's a RHD harness and is basically backasswards to a US harness. 2.) The Integra harness will not work in a 96+ Civic because it's works as a 2 piece harness, but the Civic uses a 1 piece harness. It can be salvaged for needed plugs and wiring but that's about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i also read on the hybrid honda forum that you have to add some sensors that arent already there.</TD></TR></TABLE>
Yes, you will need to add wiring for the VTEC solenoid, VTEC pressure switch, knock sensor then rewire the IAT and IACV with the ITR plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and also the motor i was gonna buy was jdm, and it says it comes with axles, and im assumming that they are also jdm, wil ihave to shorten those? how much would that cost? or would i be better off just gettin different shafts, like maybe stock CTR axles or high perfmance axles?</TD></TR></TABLE>
There's no need to shorten axles or anything like that. Read above, I already answered this
Old Dec 10, 2003 | 11:31 AM
atisvt99's Avatar
It's amazing to me how patient the Resident Hybrid folks are when it comes to inquiring minds asking legetimate questions. Go to another forum and ask a question and you'll get 6 replies bashing you for not searching before someone answers your question followed by an insult... Good stuff in here!
Old Dec 10, 2003 | 03:51 PM
b18c1guy's Avatar
wont a jdm b18cr for a good price pm me
thanxs
blake
Old Dec 10, 2003 | 04:18 PM
Default Re: (atisvt99)
thanx for the info. altho i do have one final question, if the integra connectors are backward (jdm that is), then can i go to the dealer and maybe get stock integra hook-ups, then would that work rite?
Old Dec 11, 2003 | 04:47 PM
TotalJDM.com's Avatar
Default Re: (nohondayet)
I have both the engine, and either ITR or CTR clusters if you're interested.
Andre
andre@total-boost.com
Old Dec 12, 2003 | 08:05 AM
Derek14's Avatar
Default Re: (TotalBoost)
search is your friend.... thats where i learned to do my itr swap into a 98 hb
Old Dec 12, 2003 | 08:07 AM
Derek14's Avatar
Default Re: (Derek14)
Pm'ed
Old Dec 12, 2003 | 08:45 AM
irev210's Avatar
yah people think DC2 engine wiring harness will plug right into the EK wiring harness.. they dont understand that ek doesnt have a seperate engine wiring harness
the white sam
Jul 12, 2011 02:45 AM
thats my dx
Jan 22, 2011 06:09 PM
DC2-ProdUcTiOnS
24
Apr 19, 2009 01:42 AM
Nusport_racing
Feb 29, 2004 02:36 AM
