IAVC wiring directly to ECU
Old Dec 7, 2003 | 04:54 PM
Sketch_hs's Avatar
Default IAVC wiring directly to ECU
Where in the ECU do the wires from my b16a2 OBDI motor IAVC connector connect? So i can wire it directly into my ECU. Thanks.
Old Aug 18, 2004 | 07:49 PM
pennies_hatchie's Avatar
Default Re: IAVC wiring directly to ECU (Sketch_hs)
bump .. need to know this as well
Old Aug 19, 2004 | 06:35 AM
EE_Chris's Avatar
A9 is the IACV control wire.
The other IACV wire needs +12v which typically comes from the Main Relay.
Old Aug 19, 2004 | 08:15 AM
type-t's Avatar
Default Re: IAVC wiring directly to ECU (EE_Chris)
what wire goes to the ecu...what color?
Old Aug 19, 2004 | 08:44 AM
EE_Chris's Avatar
Default Re: IAVC wiring directly to ECU (type-t)
Well, the Blk/Yel wire is +12v - process of elimination says the other wire goes to the ECU.
bcumbie
Engine Management and Tuning
Mar 16, 2012 08:49 PM
BlueShadow
Jun 1, 2005 10:08 PM
4b1z
Apr 13, 2005 09:17 AM
jtracing919
Jan 11, 2005 06:45 AM
