Skunk2/koni yellow users?
I have done a lot of reading on the topic, so just looking for these users comments on this setup. I will be daily driving, but want no finger gap/no tuck, and my car has one side higher then the other on 2 different full suspensions now, so I need coilover sleeves to level it out. Anyways, what do you think of it?? thanx
I have some Koni Yellows on my 1992 hatch.
They will certainly handle Skunk 2 spring rates. If you're trying to "tuck" then no strut will accomodate that unless you get some full coil-overs. No gap is possible, but you are limiting your travel. If you can, get some upper mounts from Ground Control that are made to increase strut travel.
thanx brother ...oh i wanted to ask you, what year are your gsr seats? i have the same ones i bought used and wondered which years those were offered ...the "type ds" ..thanx man
Mone are 1997. I think 1998 was the first year they started using purple, blue, and traces of green and pink in the seats and also had the angle adjustments on the seat cusion portion.
Scracho
11
Feb 25, 2009 03:55 AM
BeeSeriesEK4
Jan 4, 2004 09:43 PM
