Front steering tie rod, can't find it on Hondaautomotive parts/
Old Dec 6, 2003 | 09:02 PM
.jacob's Avatar
Default Front steering tie rod, can't find it on Hondaautomotive parts/
Hi, I have a bad ball joint on my right steering tie rod. I cannot find it one http://www.hondaautomotiveparts.com If someone could help me find it that'd be great. Thanks.
-Jake
Old Dec 7, 2003 | 05:23 AM
rob d's Avatar
Default Re: Front steering tie rod, can't find it on Hondaautomotive parts/ (Ninety2SiR)
What year, make, and model? This link is for a 94 dx hb:
http://www.hondaautomotivepart...R+BOX
Old Dec 7, 2003 | 07:54 AM
monicle's Avatar
part# 23 assuming you have a 92-95 cause those are the mirrors your looking for
Old Dec 7, 2003 | 10:06 AM
Bnjmn's Avatar
I would get it from Autozone.com. It is cheaper and just as good. I think mine was $20+ship. The honda site will charge handling and then shipping, which adds up on a small purchase like this.
Ben
Old Dec 7, 2003 | 10:17 AM
.jacob's Avatar
I didn't know Autozone sells this part?
Yes, it's a 1992 Civic Si.
Thanks for the links.
Old Dec 7, 2003 | 11:14 AM
.jacob's Avatar
My right inner tie rod is bad. I'm presuming that means the ball joint. All the parts I've found on Autozone are $50 up.
http://www2.autozone.com/servl...ync=1
http://www.partsamerica.com/Pa...Set=A
Old Dec 7, 2003 | 02:48 PM
monicle's Avatar
Default Re: (Ninety2SiR)
so just get the one for $23 on the link I posted a while agi. youll have the whole setup for under 40$
Old Dec 7, 2003 | 03:52 PM
joecivic93's Avatar
Default Re: (monicle)
the ball joints are something totally different,they are what allow you to turn your vehicle they are attached to the upper and lower control arms,the tie rod is what your rack and pinion is attached to 1 for each side Left and Right respectively.The tie rod itself is a "ball joint" cause it has to be able to pivot with your suspension.
keep in mind if you replace your tie rod(s) try to put the new one on with the same amount of threads exposed as the old one,and it will need to be aligned to make sure its not toed in/out.
Might look into letting a reputable shop do it for you if you dont have the proper tools,just a thought!
Old Dec 8, 2003 | 06:22 AM
monicle's Avatar
Default Re: (joecivic93)
dude the tie rod isnt a ball joint it does have a ball joint on it though and the ball joint is only a fraction of the pieces involve in what "allows you to turn the vehicle". If you back off the lock nut and mark it with some teflon tape before taking off the tie rod you can install it without NEEDING an alignment because it will only be off my a miniscule ammount and Im talking fractions of a millimeter on the steering rack.
Old Dec 8, 2003 | 12:14 PM
joecivic93's Avatar
i know that its not a ball joint but to be technical it has a ball and a socket joint and that is what allows it to pivot.as far as steering goes the upper and lower ball joint are what "allow" the tires to pivot left,right as well as up and down there is nothing else attached to the spindle except tie rods that help "steer" the car,i have worked on cars for a long time im not trying to be a smart *** i was just trying to be helpful.
if the tires are not wearing uneven then i agree you dont need an alignment but if the car is pulling left/right or steering wheel is off these are symptoms that there may be an alignment problem but tire pressure (being too high or too low) can also affect the way your car handles especially fwd.
Old Dec 8, 2003 | 12:21 PM
monicle's Avatar
true
Old Dec 8, 2003 | 01:59 PM
.jacob's Avatar
Yup, thanks. Got mine from Advanced Auto for $50
FrontwheelENT
Aug 31, 2014 07:49 AM
snowblind7x
Aug 15, 2006 08:00 AM
JokerTypeR
Nov 21, 2005 02:52 PM
Tyson
Suspension & Brakes
Aug 2, 2005 05:35 PM
Rywire
Sep 25, 2004 02:44 PM
