Will 92-95 coilovers fit 94-01 Integra?
Old Dec 6, 2003 | 08:42 PM
LittleG112's Avatar
Default Will 92-95 civic coilovers fit 94-01 Integra?
As the topic says, will they? Is it safe? is it reliable? Thanks!
Old Dec 6, 2003 | 09:22 PM
VX's Avatar
VX
Default Re: Will 92-95 civic coilovers fit 94-01 Integra? (LittleG112)
Yes they will fit with no problems what so ever.
Old Dec 6, 2003 | 09:37 PM
quik1's Avatar
Default Re: Will 92-95 civic coilovers fit 94-01 Integra? (VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Yes they will fit with no problems what so ever.</TD></TR></TABLE>
I second that.
Old Dec 6, 2003 | 09:59 PM
G U E C O's Avatar
yes
Old Dec 6, 2003 | 10:11 PM
TurboBumblBee's Avatar
Default Re: (stock93cx)
4th that.. yes they fit
Old Dec 6, 2003 | 10:26 PM
LittleG112's Avatar
Default Re: (Hybrid95CivicEX)
Thanks for the info guys! Thanks again.
Old Dec 6, 2003 | 10:33 PM
HATCHingMN's Avatar
Default Re: (LittleG112)
and again... Yes it'll fit
Old Dec 6, 2003 | 10:39 PM
743power's Avatar
Default Re: (HATCHingMN)
civic coilovers will fit on the integra, but most likely the spring rates will not be ideal. What brand are they?
Old Dec 7, 2003 | 02:37 PM
LittleG112's Avatar
Default Re: (743)
Maxspeed...
Old Dec 7, 2003 | 05:11 PM
DC4KiD's Avatar
Default Re: (743)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">civic coilovers will fit on the integra, but most likely the spring rates will not be ideal. What brand are they?</TD></TR></TABLE>Will the spring rates be too soft, or too stiff? I want to know before I get 'em.
Old Dec 7, 2003 | 05:13 PM
Filliam H. Muffman's Avatar
Default Re: (DC2 KiD)
i'd be lying if i told you they wouldnt..not...un-fit.
or something?
Old Dec 7, 2003 | 05:36 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 KiD &raquo;</TD></TR><TR><TD CLASS="quote">Will the spring rates be too soft, or too stiff? I want to know before I get 'em.</TD></TR></TABLE>
civic rates are softer than integra rates. . .
Old Dec 7, 2003 | 06:38 PM
LittleG112's Avatar
Default Re: (JUN EK9)
Man, this car eats civics for breakfast!!
http://www.japanesemotorsport.com.au/supra.mpg
Old Dec 7, 2003 | 06:50 PM
eastbay92cx's Avatar
Not 100% related, but just fyi, I was doing some research and all aftermarket springs I could find made for 4th gen civics / crxs have much higher spring rates than 5th gens (neuspeed, eibach, H&R). I was told this is due to the demand for an all-out application when the 4th gens were hot, and people decided it was a little too all-out, so they toned down the 5th gen spring rates. Just for anyone who doesn't already know and might be interested..
Old Dec 7, 2003 | 06:57 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LittleG112 &raquo;</TD></TR><TR><TD CLASS="quote">Man, this car eats civics for breakfast!!
That's the JUN Supra. I have a long 3 min video running at the same track, but I'd rather take the MINE's Skyline over it . Anyways, like someone else said, the Civic spring rates are lower/softer than the Integra rates, and the color/diameter and over all sizing is the same and is totally interchangable. With a brand like Maxspeed (or Aerospeed, Matrix, Focuz, etc, etc, etc), the spring rates are much softer than the Civic-spec springs on Eibach/Ground Control, Skunk, Tein, etc, and give the ride a more smooth and bouncy (over bumps on stock shocks) ride and can sag over time.
Old Dec 7, 2003 | 08:24 PM
Do_Ster's Avatar
to my undertstanding, most eg parts are interchangeable with 94-01, am i correct? just wanted to get that out there fyi
Old Dec 7, 2003 | 08:32 PM
Do_Ster's Avatar
i was referring to 94-01 integras
Old Dec 7, 2003 | 08:35 PM
HATCHingMN's Avatar
Default Re: (ntogethernow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntogethernow &raquo;</TD></TR><TR><TD CLASS="quote">i was referring to 94-01 integras</TD></TR></TABLE>
of course!! 3 post above!!!
Old Dec 7, 2003 | 08:36 PM
DumpedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntogethernow &raquo;</TD></TR><TR><TD CLASS="quote">to my undertstanding, most eg parts are interchangeable with 94-01, am i correct? just wanted to get that out there fyi</TD></TR></TABLE> Depends on what your talking about, Alot of the suspension parts will fit but most of the rest of the car will need modifying to make it fit
Old Dec 7, 2003 | 08:49 PM
Do_Ster's Avatar
thanks for clearing that up
Old Dec 8, 2003 | 09:47 AM
fu00fu's Avatar
to extend this question.. if i use eibach sportslines designed for integra.. which indicates 1.7 drop on the application guide..
how much drop would be expected on EG?? does it become lower like 2.0?? or higher like 1.4??
Old Dec 8, 2003 | 10:07 AM
743power's Avatar
Default Re: (fu00fu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fu00fu &raquo;</TD></TR><TR><TD CLASS="quote">to extend this question.. if i use eibach sportslines designed for integra.. which indicates 1.7 drop on the application guide..
how much drop would be expected on EG?? does it become lower like 2.0?? or higher like 1.4??</TD></TR></TABLE>
probably about an inch higher in the front, and about the same in the back, maybe half an inch higher.
Old Dec 8, 2003 | 11:32 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (Slammed Si)
i have an eg with 94+ teg coils. it's a stiffer spring rate(bumpier ride for the eg) but that's ok for the track.
Old Dec 8, 2003 | 11:41 AM
LittleG112's Avatar
Default Re: (vtecb20coupe)
I heard that nothing rides like stock springs... but i was wondering, do they make a coilover kit that lowers your car while maintaining a smooth stock ride?
Old Dec 8, 2003 | 12:53 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LittleG112 &raquo;</TD></TR><TR><TD CLASS="quote">I heard that nothing rides like stock springs... but i was wondering, do they make a coilover kit that lowers your car while maintaining a smooth stock ride?</TD></TR></TABLE>
The Tokico kit is pretty comfy. I had it on my old civic, and I never realized how comfotable/soft they were until I put the A'PEXi N1 on my new civic. The tokico is probably the only adjustable ride height "coilovers" with progressively wound springs.
97Integra
10
Oct 21, 2021 04:11 PM
ohsnapzafingcu
Jun 19, 2006 08:59 PM
dpw41285
Nov 27, 2004 09:59 AM
Riceonmaisok
Nov 9, 2003 01:36 AM
SiC CiViC
Oct 3, 2002 07:49 AM
