how to identify a B18c cylinder head?
Old Dec 6, 2003 | 08:01 PM
9THREECIVIC's Avatar
Default how to identify a B18c cylinder head?
well a guy is trying to sell me a 99 b18c GSR cylinder head. but i want to know how to identify it so i know for sure its a Gsr head. what should i look for on the cylinder head? and last, how would i know if the head is still good? any info or tips would help thank for your time
Old Dec 6, 2003 | 08:27 PM
SiR831's Avatar
Default Re: how to identify a B18c cylinder head? (9THREECIVIC)
i think it should say P72
Old Dec 6, 2003 | 08:47 PM
speedracer9k's Avatar
the valve cover for the b18's looks differents from the b16 and other b series heads
Old Dec 6, 2003 | 09:45 PM
quik1's Avatar
Default Re: (speedracer9k)
If it has the intake manifold on it, it will curl down if its any other b-series it curls up.The only way to know if it is good is to take it to a machine shop and get it pressure tested. You can also visually check it for obvious cracks in the combustion chamber.
Old Dec 6, 2003 | 09:58 PM
G U E C O's Avatar
there are too numbers on the head to identify the year, i saw a picture here search
Old Dec 6, 2003 | 10:17 PM
TurboBumblBee's Avatar
Default Re: (stock93cx)
look for p72 on the head and also there is a year stamp like said above.. its 30 degrees outside or i would go and check to see how its stamped..
2000si
Nov 27, 2011 07:20 PM
legendboy
Apr 12, 2005 04:27 PM
battlefield
Dec 24, 2002 09:46 AM
D
Jul 12, 2002 05:32 PM
g's integ
May 23, 2002 01:16 PM
