Question about Wheel Spacers and Spoon Calipers
I am hoping to purchase the Spoon calipers soon, but I am unsure if they will fit under my WORK wheels without spacers (I doubt they will). What is the best way to tell if they will fit before purchasing? How do you go about determing the size of wheel spacers needed?
My tires are not actually up inside the wheel-well, but there doesn't seem to be much space between the outside edge of the tire and the fender. Who is using wheel spacers (what size?) on a lowered car (not slammed) without problems?
Last question: where is the best place to buy H&R wheels spacers? I don't see them on the Tirerack site.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spikey »</TD></TR><TR><TD CLASS="quote">which work wheel and what size?</TD></TR></TABLE>
15x7 RSZ-R. 44 offset.
isnt spoon now actually using work wheels on their cars instead of their own wheels. im sure the calipers must fit without spacers, but im not sure.
_______
hahahahah....so are you sure or not?....hahaha........ah oh well...had to be there i guess
_______
.....if you will measure and take a pic of the distance from your rotor to the closest part of your inner rim, I will try to estimate if your wheel would clear.
It'll be close - judging from the offset you have, but the real determining factor is the shape of the spokes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">.....if you will measure and take a pic of the distance from your rotor to the closest part of your inner rim, I will try to estimate if your wheel would clear.
It'll be close - judging from the offset you have, but the real determining factor is the shape of the spokes. </TD></TR></TABLE>
Cool, I'll do that.
For those that said they would fit, what makes you so sure?
Cool, I'll do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">15x7 RSZ-R. 44 offset.</TD></TR></TABLE>
How do these compare with the 15 x 7.5 SSR Comps in offset and spoke curvature.
I know for a fact that the SSR's fit over my Smurf calipers w/o spacers or any other such issues.
No, I'm not sure of the offset on the SSR's, but their sitting around here somewhere and I'll take another look inside the wheels in a bit,
though when I looked the other day it was hard to tell which number was the offset since none seemed appropriate. Ed
There is ~ a bit over 4.5 cm from the rotor to the wheel spoke.
Here are some photos. Any help knowing if the Spoon calipers will fit is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2-R »</TD></TR><TR><TD CLASS="quote">they will fit!</TD></TR></TABLE>Hell no!!! I have 16x7 RSZ-Rs with 41mm offset. I have to run atleast 3mm spacers up front!
in your case, i think you will undoubtedly need a spacer
most likely it won't fit, and as SuperTwinz posted... he still needs spacers with a 16x7 wheel
I just finished taking some pics (unfortunately both Imagestation and We-Todd are down), but also measured the distance from the rotor surface to the inside of the stock ITR wheel's spoke.
It's about 2.0" needed to clear the Spoon caliper using the stock wheels.
Yeah, looks like you might need a spacer ... Ed
Yea, I was pretty set on the fact that I most likely needed to use spacers. What about my other questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">Last question: where is the best place to buy H&R wheels spacers? I don't see them on the Tirerack site.</TD></TR></TABLE>
Found some @ King Motorsports
http://www.kingmotorsports.com...nsion
i remember heard from people with work emotion cr 16x7 offset 44 will fits with spoon calipers.. so i don't see why it can't fits!!
but maybe u should double check it with some shop? or email A&J i think they should be able to find out!! if it's possible for u to find anyone with spoon calipers in local test fits
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">Found some @ King Motorsports</TD></TR></TABLE>
That's where I got my H&R spacers from.
Prompt delivery and great customer service.
King Motorsports
*looks at camera and smiles*
King Motorsports
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01SpecR »</TD></TR><TR><TD CLASS="quote">i remember heard from people with work emotion cr 16x7 offset 44 will fits with spoon calipers.. so i don't see why it can't fits!!
I think the Emotion CR's with that offset clear due to the different design of the wheel. The RSZ-R's flux has is a 2-piece design with the spokes sitting nearer the calipers then the 1-piece CR's, so there isn't sufficient clearance for the spoon calipers w/o running spacers...
