wiring help plz.....for vss...yes i searched
Old Dec 6, 2003 | 03:36 PM
CTRwannaB's Avatar
Default wiring help plz.....for vss...yes i searched
well here goes i need to get it working.
i searched and it did help to much.
tried to change clusters to see if it help.......nope
checked to see if vss is working.................yep
the only thing i can think of is that there is a ground some where in the blu/wht+gray dots wire. the wire sending back the info.
i am no wiring genius but i don't think that when i hook up a voltmeter thing to it, and i send power through the wire. i can touch a any metal on the car and it'll show a connection?
is that suppose to happen. i thought it was suppose to be sheilded and everything?
any help will be cool. plus i just got back from the garage and damn its cold
Old Dec 6, 2003 | 04:12 PM
Eyewitness's Avatar
Default Re: wiring help plz.....for vss...yes i searched (CTRwannaB)
The vss has 3 wires coming from it.
yel/blue
yel/wht (send)
blk (ground)
The yel/wht wire should go from the sensor the the clip. then it changes color to yel/blue from the clip on to the ecu. the yel/blue going in the ecu should be pinned in B10. the blk can be grounded to the chassis
This is information for a 92-95 civic harness.
Old Dec 6, 2003 | 04:35 PM
CTRwannaB's Avatar
Default Re: wiring help plz.....for vss...yes i searched (Eyewitness)
soryy forgot to post my yr
99 cx hatch
my colors are
blk/wht...........ignition
blk.................ground
blu/wht...........vss out
Old Dec 6, 2003 | 04:43 PM
Eyewitness's Avatar
Im not exactly clear on what your asking. But if your throwing a code for VSS. Check the ground. Reset you ecu. See if your still throwing the code.
Old Dec 6, 2003 | 04:49 PM
CTRwannaB's Avatar
the ground is fine.
i don't know how many times i reset the ecu lol tryin to fix it
i think the vss out/signal wire has a ground on it some where
somewhere told me to try and directly wire the vss to the cluster and see if that'll work. if so that would mean that my wire has a ground...i think
Old Dec 6, 2003 | 04:52 PM
Eyewitness's Avatar
Ouch....sorry bro not sure on that one. B18C5-EH2 should be able to answer that one though.
eg6madness
Nov 17, 2007 04:46 PM
Batoutahell
Jan 29, 2006 06:45 AM
Hyaboosta
Jan 11, 2005 05:48 PM
I8ayellowcrayon
May 24, 2004 08:21 PM
