just failed smog test
Old Dec 6, 2003 | 01:31 PM
sunlei's Avatar
Default just failed smog test
i got a 93 stock vtec aaaaaand i just failed my smog test pretty hardcore
i did a search and nothing really came up so im wondering what i might need to fix and how much this is gonna cost
TEST RESULTS (1)15mph (2)25mph
HC (ppm)
max gross polluter measured
1 88 275 159
2 53 225 119
CO (%)
1 .52 2.02 .54
2 .50 2.00 .49
NO (ppm)
1 704 1936 2342
2 738 1736 1843
any help appreciated
Old Dec 6, 2003 | 07:59 PM
Jimmy's Avatar
Global Moderator
Default Re: just failed smog test (sunlei)
Clean your engine out good (tuneup) and check your O2 sensor
Old Dec 6, 2003 | 08:43 PM
speedracer9k's Avatar
what is your ignition timing set at...it should be 15 degrees. I failed my smog test because my timing was off which messed all the number up. After i changed the timing back to 15 deg. it changed all the numbers and i passed. Also make sure you run your car for a while before the smog test to heat up your cat which helps, and when you get to the smog station leave your car running to keep it hot. DAMN CA EMMISIONS ARE TOO STRICT
666JTK666
Jan 31, 2016 03:49 PM
dman81
Oct 9, 2015 06:49 PM
rotascircuit
Oct 10, 2009 09:28 AM
stilzx61
Jan 9, 2004 12:03 AM
crxtreme27
Jun 12, 2003 04:15 PM
