Re: Info request on 89 Accord parts swap-Technical info.?
Old Dec 6, 2003 | 11:51 AM
Hondamanruss's Avatar
Default Re: Info request on 89 Accord parts swap-Technical info.?
Hello,
I currently own an 89 Honda Accord LXI and have found an 89 Accord SEI parts car in the junkyard.
My question is: Will the SEI rear with discs be transferrable to my LXI with drums.
I do realize I'll need the knuckles although, I'm unsure if this is a feasible swap and of what other parts I may need, in order to accomplish this task?
Any assistance with this inquiry would be greatly appreciated.
Regards,
Russ
Old Dec 6, 2003 | 12:18 PM
89_LXi's Avatar
Default Re: Info request on 89 Accord parts swap-Technical info.? (Hondamanruss)
Yep, very easy swap! I did it myself several months ago and they've worked perfect so far!
http://www.3geez.com/showthrea...82915
That's my own pictures of my rear disc swap. You just need the rear knuckle assembly AND e-brake cables (don't cut them!!!), and proportioning valve. Master cylinder is the same so you can just reuse your old one. Then it's just a simple unbolt the old assembly, take it out, put the new one in, bolt it in! Just be sure and use a flare wrench on the brake fittings or they will strip very easily, and make sure the wheel bearings, rotors, calipers, and hoses are in good shape.
Good luck!
Robert Lindqu
Jan 14, 2019 06:06 PM
wwolf771177
Jan 10, 2014 06:41 AM
shr0olvl
Jan 16, 2005 11:16 PM
1990 accord ex
Sep 24, 2004 01:15 PM
D114
Oct 27, 2002 05:49 AM
