What will i get for HP?
I am actually currently building the motor right now. But just wanted what kind of HP numbers to be expecting. Here is my build:
B18B Block
Darton M.I.D. Sleeves
JE 85mm 12:5.1 Compression Pistons
Crower All Motor Connecting Rods
Z10 Block Gurdle w/main studs
Type R oil pump
Pro Drive Oil pump gear
b18c5 cylinder head
Skunk2 high comp. valves
Skunk2 Stage 2 cams
Skunk2 Cam Gears
Skunk2 Valve Springs & Retainers
Alaniz Competition Head Work
ITR Intake Manifold
Erick's Racing Throttle Body 72-70mm
ACT Xtreme Pressure Plate
ACT 6 Puck Disc
ACT Prolite Flywheel
Quaife ATB LSD
Hondata S200
RC engineering 310cc Injectors
Just want to know if anyone has done a similar build
B18B Block
Type R oil pump
b18c5 cylinder head
Skunk2 Stage 2 cams
Skunk2 Cam Gears
ITR Intake Manifold
ACT 6 Puck Disc
Quaife ATB LSD
Hondata S200
sorry i dont know how much Hp your goin to make but i had a question for ya ...how much did you pay for the Darton M.I.D. sleeves ..and by the way that looks be be a very nice setup your goin to be running...
