HELP H & F Series Guru's
Old Dec 6, 2003 | 10:05 AM
WNYAccordLX's Avatar
Default HELP H & F Series Guru's
Im buying an f20B. I searched and was wondering about a f20b timing belt and clutch. Can I use the h22 timing belt and clutch??
Old Dec 6, 2003 | 10:46 AM
SilverEk3dr's Avatar
Default Re: HELP H & F Series Guru's (WNYAccordLX)
The F20B is only different internally from the H22. Its basically the same block
Old Dec 6, 2003 | 01:27 PM
so the crank gear is the same size?
Old Dec 6, 2003 | 01:36 PM
This One's Avatar
Default Re: (WNYAccordLX)
I ordered everything for motor last week, you need to order h22 stuff.....
Old Dec 6, 2003 | 01:37 PM
Yes. The h22 & F20b very similar, and I can see no reason why an H22 timing belt wouldnt fit perfect.
Old Dec 6, 2003 | 04:08 PM
Newman's Avatar
New User
Default Re: HELP H & F Series Guru's (SilverEk3dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr &raquo;</TD></TR><TR><TD CLASS="quote">The F20B is only different internally from the H22. Its basically the same block</TD></TR></TABLE>
Correct. External parts like belts, pumps, brackets, etc, are all the same (like when doing B18A/B and B20B/Z swaps... same longblock & same physical size). The internals are different, like different crank & rods (destroked) and different pistons (for higher compression), but has nothing to do with what belts & pumps you use.
Golding.racing
Feb 7, 2012 02:01 PM
monster accord
Jul 1, 2007 06:36 PM
chingro
May 3, 2007 09:27 PM
EuRoBrO
Jul 19, 2004 06:57 AM
EK22Tim
Oct 18, 2002 04:15 AM
