All b-series spark plug wires the same?
Old Dec 6, 2003 | 12:14 AM
Unjockable's Avatar
New User
Default All b-series spark plug wires the same?
would a LS wire fit into a SI, GSR, etc? basically, non-vtec wires work with vtec head? did a search and half of the people said yes, the other said no. need someone that knows for sure to answer.
Old Dec 6, 2003 | 12:40 AM
JSJ EG6's Avatar
Default Re: All b-series spark plug wires the same? (Unjockable)
i got b16 wires on my ls motor.they work but they dont fit corect.
Old Dec 6, 2003 | 12:56 AM
Unjockable's Avatar
New User
Default Re: All b-series spark plug wires the same? (TEAM JSJ)
got any pics? how off is it? so LS spark plug wires should work with a B16 but will have fitment issues?
Old Dec 6, 2003 | 01:35 AM
ace1875's Avatar
It will not fit very well around the valve cover spark plug area. I wouldn't put it on an LS cause unlike the VTEC motors that have a spark plug cover the LS doesn't. that will cause some water and deb. to go inside the cylinder head.
Old Dec 6, 2003 | 01:58 AM
slammed_93_hatch's Avatar
Default Re: All b-series spark plug wires the same? (ace1875)
i wouldn't do it
Old Dec 6, 2003 | 09:32 AM
JSJ EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 &raquo;</TD></TR><TR><TD CLASS="quote">It will not fit very well around the valve cover spark plug area. I wouldn't put it on an LS cause unlike the VTEC motors that have a spark plug cover the LS doesn't. that will cause some water and deb. to go inside the cylinder head.</TD></TR></TABLE>
nothing bad happen to me..
i even use SOHC wires before too...........
Old Dec 6, 2003 | 11:16 AM
Anthonyl469's Avatar
i have auto zone 93 gsr wires on my 01 b18c5 Im cheap, and they work just as good as the ngk power wires... autozone axles and wires =
Old Dec 6, 2003 | 11:19 AM
G U E C O's Avatar
my friend is useing accord spark plug wires on his b18c1 and everything works right.
Sic_DA_Nine
Dec 14, 2005 01:35 PM
GreenTeaLS
Jul 16, 2005 05:19 PM
DubyaAye
Mar 8, 2005 01:58 PM
ubreak_ubuy
May 20, 2004 12:04 PM
IamVtec
Apr 8, 2003 08:52 PM
