Race Springs
RIP 1032
what springs do you guys run? i'm looking for a stiff ride with a nice low drop. what companies offer stiff springrates with a nice drop? a friend of mine mentioned KGMM springs, but it seems no one in the states carry this brand. i was thinking 8kg for the front and 6kg for the rear. you think thats to stiff for a daily driver? keep in mind i like feeling every pothole and pebble i go over
. i know coilovers sounds like an easy anwser since i want a nice drop and all. the coilover kit i would want is way to damn expensive. let me know what you guys think.
i bought a knock off ground control coil over set for about 140 and it works fine for me...although i did drop it the max the coil overs would let me....not sure if u want ur car THAT low
KONI Sport shocks and custom rated coilover springs. http://www.truechoice.com should give you a start. I think each spring is somewhere between $50-75.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by life sux die »</TD></TR><TR><TD CLASS="quote">yeah, i was thinking tokico illumunas with skunk2 coilovers but my friends say that skunk2's coilover kit is kinda soft.</TD></TR></TABLE>
skunks comes in 8kg and 6kg for civics which is around 450, 350. same as ground control.
you can get integra spring rates which are 10kg and 8kg. (550lb, 450lb)
i have skunks 8,6kg. still a bit soft imo when my damper is set at #3. step upto #5, FIRM.
redDAinteg
Nov 7, 2005 03:00 PM
