reseting ECU!?!?!
Old Dec 5, 2003 | 11:20 AM
SleepnCiViC's Avatar
Default reseting ECU!?!?!
ok guys how long do i have to disconnect the negative battery wire to reset the battery. some said leave it off for 10 seconds some people said 15min!! and car has to be off correct?
Old Dec 5, 2003 | 11:23 AM
pyromaster's Avatar
Default Re: reseting ECU!?!?! (SleepnCiViC)
i usually do the neg terminal for about 10 min
you can also pull the backup fuse for about 15 seconds
yes, you would probably want the car to be off when you're disconnecting the battery IMO and definately to reset the ECU (how would it reset if it's running?)
Old Dec 5, 2003 | 11:27 AM
Default Re: reseting ECU!?!?! (pyromaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyromaster &raquo;</TD></TR><TR><TD CLASS="quote">i usually do the neg terminal for about 10 min
yes, you would probably want the car to be off when you're disconnecting the battery IMO and definately to reset the ECU (how would it reset if it's running?) </TD></TR></TABLE>
yeh i just though about that, very dumb comment by me.
but anyway the back up fuse is that the 7.5 fuse
Old Dec 5, 2003 | 11:29 AM
pyromaster's Avatar
that's the one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">
the back up fuse is that the 7.5 fuse</TD></TR></TABLE>
Old Dec 5, 2003 | 11:32 AM
how can be certain that the ECU actually reset?
Old Dec 5, 2003 | 11:35 AM
pyromaster's Avatar
get a CEL and see if it goes away
you'll have to reset your clock and radio channels
Old Dec 5, 2003 | 02:56 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">how can be certain that the ECU actually reset?</TD></TR></TABLE>
well.. if you have cel.. it might go away.. and you idle will act different - it will do that for next few start up as it readjusts.. you only need to disconnect for seconds..
EFstyle
Oct 5, 2007 10:21 PM
Boring
10
Dec 3, 2004 11:31 AM
Pearlude
Nov 14, 2004 06:41 PM
bigslimdog
Mar 30, 2004 03:07 PM
