whats a good camber kit, no squeals, okay to autocross with?
Old Sep 18, 2001 | 12:17 AM
MintyDip's Avatar
Default whats a good camber kit, no squeals, okay to autocross with?
whats a good camber kit that does not squeals and is okay to autocross with?
Any opinions? My cambers are about -1.25 to -1 all around.
i jsut had to replace my front 2 tires cause of massive inner tire ware....
my re730 had a little more then 20k mile and a lot of meat left, but the inner ware was a goner....
Old Sep 18, 2001 | 01:07 AM
SpecR_EK's Avatar
New User
Default Re: whats a good camber kit, no squeals, okay to autocross with? (MintyDip)
I jus picked up a camber kit from specialty products. They have a groupbuy on them right now. I bought a whole A-arm replacement that adjusts for camber and caster. Very nice quality, looks almost OE.
Check it out here.
http://www.groupbuycenter.com/buy.as...ad&row_id=3251
Old Sep 18, 2001 | 06:23 AM
timberwulf's Avatar
Just remember that if you put on a camber kit, you're out of GS.
Old Sep 18, 2001 | 07:12 AM
Alexis's Avatar
New User
You really don't have that much negative camber. It's almost like stock. Check your toe settings that could be your problem. King Motorsports makes the only camber kit that really works.
Old Sep 18, 2001 | 07:13 AM
Asahi's Avatar
LOL, Minty isn't in GS anyway!
-1.25 and you are having tire wear problems?
IT sin't the camber that is a problem.
Have the toe checked. Have you gotten an alignmentlately? Do you ever rotate your tires? What tire pressure do you run and do you check it OFTEN?
I run -2 degrees of camber and 1/4" total toe out in the front and don't have tiure wear problems. I do rotate the tires every 1500-2000 miles and I watch my tire pressure like a hawk. I run RE730's at about 33-34 psi. I race them at 38-39 psi.
I don't think you need a acamber kit I think you need an alignment and to rotate!
Trey
Old Sep 18, 2001 | 08:56 AM
356racing's Avatar
Default Re: whats a good camber kit, no squeals, okay to autocross with? (Alexis)
Who pulled the wool over your eyes?
Old Sep 18, 2001 | 09:11 AM
MintyDip's Avatar
Default Re: whats a good camber kit, no squeals, okay to autocross with? (Carlex)
carlex: yeah i do rotate ever other oil change , 7000miles...
its realy weird. these tires have 300 tread ware,
the last time i got an anlinment was 9 months ago....maybe thats the thing?
According to the dealer ship, my camber and toe were very close to facorty specs, but that was 9 months ago.
here are a couple recent pictures of my car......camber doesnt look bad at all...maybe i just need to get it aligned
[Modified by MintyDip, 10:12 AM 9/18/2001]
Old Sep 18, 2001 | 09:34 AM
Dipshit Dan's Avatar
I agree with Trey. I had 2 degrees or just over that of negative camber and I had ZERO inner tire wear. I just corner weighted the car and aligned it. I also rotate tires every 3-4000 miles.
Old Sep 18, 2001 | 09:50 AM
MintyDip's Avatar
Default Re: whats a good camber kit, no squeals, okay to autocross with? (God)
how often do you guys drive with -2??
my car is my only car...i do about 300-400 miles a week.
Old Sep 18, 2001 | 12:04 PM
Asahi's Avatar
I have put 19,100 miles on my car in the last 11 months and 2 weeks.
The key I think is TOE. Have them check it again. Camber should be ok up to -2. Also how low is your car?
Old Sep 18, 2001 | 01:40 PM
sgT's Avatar
sgT
about 100k miles with -2.25 to -2.5 neg camber and *0* abnormal tire wear.
Regular alignments are key.
Old Sep 18, 2001 | 01:44 PM
MintyDip's Avatar
Default Re: whats a good camber kit, no squeals, okay to autocross with? (sgT)
how often do you guys get your alignment?
Old Sep 18, 2001 | 01:56 PM
red97gsr's Avatar
Yep! If you have 0 camber and 0 toe in/out then you will have minimal tire wear. If you car has 0 camber and the toe is off (in or out), it will just drag the tires evenly across and you'll just have faster wear than usual throughout (even wear, but faster wear). If there is some camber and the toe is off, you are dragging the tires on that inside edge. So toe settings become very important once you start increasing negative camber.
My camber settings are kinda like yours ( -1.3 front/-0.75 rear) and I don't have uneven wear with wider and way softer tires than stock. I got my toe settings aligned with me sitting in the driver's seat and little over half a tank of gas. That way my toe settings are aligned with the same approximate weight in the car as the car sees everyday.
[Modified by red97gsr, 4:58 PM 9/18/2001]
Old Sep 18, 2001 | 03:29 PM
MintyDip's Avatar
Default Re: whats a good camber kit, no squeals, okay to autocross with? (red97gsr)
they let u sit in the car while aligning it???
where can i do this?
Old Sep 19, 2001 | 04:16 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i just had my car cornerweighted and will have it alighned soon. i will post pics when i get them up on the site. as far as camber adjusters, i use Skunk2 upper c/arms in front, and a J's racing of japan rear camber kit. for J's products, go to www.racingcraft.com i think they are about $200 for the set. they are hard durometer rubber, and won't squeak like the ingalls i had prior.
Old Sep 19, 2001 | 06:14 AM
Default Re: whats a good camber kit, no squeals, okay to autocross with? (rodney)
My car had 48000 miles on it. A lot of people have bad toe in or out and they think the camber is causing tire wear. They are wasting their money on a camber kit. If you want to correct camber in the rear just use washers and longer bolts. Almost free and does the job just fine.
Old Sep 19, 2001 | 09:32 AM
AoiGSR's Avatar
25 Year Member
Minty,
Come to Torrance, There is an alignment shop called West End Alignment. You are advised to sit in the car while Darrin does the alignment. Lots of So Cal guys go through him.
Go to West End Alignment in Gardena and talk to Darin. He also does corner weighing for adj coilovers.
18008 South Vermont Ave.
Gardena, CA
310-808-9233
price is $75 (they split up the cost for each section, but jast do all 4 wheels )
-AoiB0t, who thanks Yoshi234 for the recommendation.
95_red_dc
Suspension & Brakes
Oct 13, 2008 11:29 AM
bmoua
Suspension & Brakes
Oct 19, 2007 04:00 AM
pr0phet
Nov 22, 2005 03:59 PM
imonx850
Suspension & Brakes
Mar 14, 2005 08:47 AM
AB16A2T
31
Oct 15, 2002 09:36 AM
