D16 with LS rods.....need actual answers
Old Dec 5, 2003 | 08:12 AM
yusoslo's Avatar
Default D16 with LS rods.....need actual answers
This is not too complicated of a thing but I hear so many different answers to.....
Does the block have to be notched?????
Also who has done this and where do you get bushings for the rods to mate to the piston's wrist pin?
Old Dec 5, 2003 | 08:36 AM
SloCivicHMM's Avatar
Default Re: D16 with LS rods.....need actual answers (yusoslo)
I heard the block has to be notched thats it....
Old Dec 5, 2003 | 09:16 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
no notching the block. big end needs to be machined down. small end needs a bushing installed for floating wrist. that means after market pistons.
if you need numbers let me know.
stan
Old Dec 5, 2003 | 09:55 AM
RyanEJ8's Avatar
Notching only needs to be done with Eagles and D16 block. You won't need to notch with the LS rods.
Old Dec 5, 2003 | 10:40 AM
yusoslo's Avatar
Default Re: D16 with LS rods.....need actual answers (RyanCivic2000)
damn, I dont want to get aftermarket pistons, I was just trying to keep the cost down. Oh well i guess I will boost on stock rods
Old Dec 5, 2003 | 10:43 AM
go here for cheap rod/piston combo for boost.
https://honda-tech.com/zerothread?id=267641
Stan
Old Dec 6, 2003 | 02:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: D16 with LS rods.....need actual answers (90crxsi)
hrm, thin the LS rod on the big end by .043", use a "stock" piston, and slap it all together for a 12.5:1 NA monster.
If you search, you might even find a "NPG/GX" rod/piston that needs no mods to fit.
NEVER EVER a bushing.
Old Dec 6, 2003 | 04:42 AM
kwik92hb's Avatar
i thougt they would clear just fine......please educate me about cause my stuff is at the machine shop as we speak...eagle rods..je piston combo.d16z6 block...
Old Dec 8, 2003 | 05:09 PM
virginia_dude's Avatar
yes but you need to have internals rebalanced afterwards. WHich I am certain is obvious to everyone regardless of what rods end up in it.
Honda HP
Nov 8, 2010 07:23 AM
sabot808
Apr 28, 2005 06:25 PM
SwappedTURBOegg
Mar 9, 2005 08:35 AM
yusoslo
Dec 16, 2003 06:56 PM
ViperRedCRX
Dec 17, 2002 09:45 AM
