loud pistons?????
went to test drive a 2000 r last night and there was a loud. knock but he said it was the pistons they are juust loud. they were arias 11:5:1 compression pistons and eagle pods. it also has a jun valve train. I have never heard of this till last night. is it true or is it possibe that the valves are bent. It also has a jun ecu.
it doesnt sound like the injectors. He said they were still stock. also when you rev it out to 9600 and shift quickly the oil light comes on for a split second. is this due to oil starvation. would i need to upgrade the oil pump.
Im getting a knock sound as well but Im running low compression 9:1 weisco pistons with eagle rods I've been told there should be knock when you start up but it should go away once the car is warmed up
anyway I have a video clip of the sound my motor is making letme know if yours sounds similar or if anyone else cares to chime in
http://65.49.87.73/MotorSound.avi
82lude
Jul 27, 2004 10:03 PM
turboex
Mar 28, 2002 07:32 PM
