Is this the cam seal that always leaks?
Is this the cam seal next to the distributer that always leaks? I believe mine to be leaking cause i got oil down the side of the head. Its #8 on the diagram. Just making sure before i order.
yes thats the little ****** that always leaks, took me like 10 minutes to change , and fixed my oil leak. good thing too, i thought it was my vtec solinoid at first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione »</TD></TR><TR><TD CLASS="quote">eleventy billion percent better than the stock plastic POS.</TD></TR></TABLE>
the STR one is billet alum, while the OEM is a rubber/plastic compound. Honda has altered the compound the newer ones are made from. The old ones would get hard and crack, thus causing the oil leak.
STR =
STR =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! »</TD></TR><TR><TD CLASS="quote">Honda has altered the compound the newer ones are made from. The old ones would get hard and crack, thus causing the oil leak.</TD></TR></TABLE>
That's the first I've heard that Honda had revised the compound. I know the one I took out of my '97 has the consistency of a lego.
The aftermarket ones may be more expensive than a stock replacement, but at $21, an STR one is hardly gonna break the bank. And you'll never need to worry about it again - cheap insurance, if you ask me.
A retainer is what the recall fix is by Honda for the seal. It basically holds the seal in from what I understand. So, if you can buy this retainer for 4 bucks, why buy some "super duper" one for 20 if they both accomplish the same thing?
JDMisGOOD
12
Nov 12, 2005 09:54 PM
Austin
Jul 26, 2005 08:14 PM
